Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 29-09-2012, 11:31
miki miki is offline
miki is an unknown quantity at this point
PROBLEM with Retrieve image from MySql to Timage Using Delphi
Hello,
I have problem to retrieve image from MySql database to Timage using delphi.
I can load image in to TImage (using TOpenPictureDialog). I can save Picture From Timage into MySql database. But I cant retrieve and show image into TImage.
sometimes I can retrieve image , but show only first image from database. I want to scroll DBGrid and see how pictures are changing.
I use this code for load, save and retrieve picture.
-Load image
var
sDir : string;
begin
OpenPictureDialog1.Execute;
sDir := OpenPictureDialog1.FileName;
Image1.Picture.LoadFromFile(sDir);
end;
-save image
var
AStream : TMemoryStream;AStream := TMemoryStream.Create;
try
Image1.Picture.Graphic.SaveToStream(AStream);
AStream.Position := 0;
if ADODataSet1.Active then
begin
ADODataSet1.Edit;
TBlobField(ADODataSet1.FieldByName('MyField')).Loa dFromStream(AStream);
ADODataSet1.Post;
end;
finally
AStream.Free;
end;
-Retrieve image
var
begin
try
begin
TBlobField(ADODataSet1.FieldByName('MyField')).Sav eToStream(AStream);
Image1.Picture.Graphic.LoadFromStream(AStream);
end;
finally
AStream.Free;
end;
end;
Unread 29-09-2012, 11:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: PROBLEM with Retrieve image from MySql to Timage Using Delphi
Hi, this is not a forum about the delphi programming language, it's a robotics forum. Sorry.
Unread 29-09-2012, 11:47
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Hi miki.
This is not a forum for Delphi software.
It is for a high school robotics competition called FIRST Robotics.
I doubt you get many helpful responses.
Good luck with your problem and if you would like to learn more about FIRST please explore more here and go to usfirst.org.
Unread 29-09-2012, 11:50
Try one of these forums:
http://www.tek-tips.com/viewthread.cfm?qid=1694533
http://forums.devshed.com/delphi-programming-90/
https://forums.embarcadero.com/index.jspa
Unread 29-09-2012, 12:47
Sorry, my mistake.
Thank you for your time. Best regards Miki.
