Go to Post If you want something done about it, than do something about it. - Tetraman [more]
Unread 29-09-2012, 20:40
Andrew Lawrence
Posts: n/a
AndyMark 3/8-16 x 7 Hex Head Bolt bending
Does anyone have any experience with the AndyMark 3/8-16 x 7 Hex Head Bolt used in the kit of parts drivetrain bending or breaking? I was using them to design a drivetrain, but my friend said his bent this year.
Unread 29-09-2012, 21:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: AndyMark 3/8-16 x 7 Hex Head Bolt bending
I am pretty sure they are just a grade 5 bolts. I am are pretty sure they are what we used for our 2010 Break Away chassis axles. If so we have been pretty abusive & they have held up.
Unread 29-09-2012, 21:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I'm pretty sure he meant 7" and not grade 7.
Unread 29-09-2012, 22:22
Andrew Lawrence
Posts: n/a
This part: http://www.andymark.com/product-p/am-1055.htm
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We have bent the KOP bolts in the KOP long configuration before [8inch wheels, Logomotion lots hard driving]. After we realized this we got some Grade 8 bolts and didn't have any problems.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 29-09-2012, 22:24
Andrew Lawrence
Posts: n/a
Originally Posted by Mk.32 View Post
We have bent the KOP bolts in the KOP long configuration before [8inch wheels, Logomotion lots hard driving]. After we realized this we got some Grade 8 blots and didn't have any problems.
Do you have any grade 8 bolts you'd suggest using?
Unread 29-09-2012, 22:33
AdamHeard's Avatar
Lead Mentor
Grade 8 is a rating, not a brand. So if you find anything marked grade 8, you're fine.
Home Depot might have them, unsure. Any industrial supplier should
Socket Head bolts aren't grade 8, but are similarly strong.
Unread 29-09-2012, 23:24
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Quick check of Mcmaster shows part #91257A650 is $12.13 for a 5 pack of grade 8 bolts if you don't have a local industrial supplier.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-09-2012, 23:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We used the kit chassis for logomotion, we bent the long bolts that hold on the wheels. That aspect of that chassis is not a very good design, if your robot is going to do things like drive into a wall with it's arm extended. The load of the robot falling back onto it's wheels will bend the axles.
Using a higher grade bolt might fix the problem, but it's still not a very good design.
Unread 29-09-2012, 23:32
Andrew Lawrence
Posts: n/a
This is exactly what i needed. Thanks!
Unread 30-09-2012, 04:56
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
We use these all the time. They're really robust, in 2011 6 of them held the weight of our entire max-weighted robot for nearly a year and never complained, but they do bend. I'm pretty sure we don't have a single one of these that is completely straight.
Don't be too alarmed though, most of these bends are unnoticable to the untrained eye (maybe a degree or two).
Unread 30-09-2012, 10:54
Jenn Feathers's Avatar
Jenn Feathers Jenn Feathers is offline
FABLab Team Captain
FRC #2252 (Mavericks)
Jenn Feathers will become famous soon enough
We had one bend almost immediately, It was a pain to get out.
<a href=http://www.mavericks2252.net target=_blank>http://www.mavericks2252.net</a>
“Wants to see FIRST design a game that involves Formula - 1 Power Boat racing or possibly a TARDIS”
Unread 30-09-2012, 11:07
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Those bolts are good, but they will bend, our Logomotion bot bent all 6 and then 6 more in one season... and it only weighed 84 pounds.
The biggest issue, is that once they bend they are incredibly difficult to remove for replacement. Ours bent to the point where they caused our wheels to wobble and started throwing chains. We use grade 8 bolts now and have had no problems.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 30-09-2012, 11:25
MrForbes's Avatar
AKA: Jim
That's the problem...then you get to call in a back up robot and watch the finals from the sidelines. BTDT
Unread 30-09-2012, 11:51
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Try replacing them with socket head shoulder screws aka stripper bolts.
http://www.mcmaster.com/#shoulder-screws/=jintlq
