Go to Post My opinion doesn't matter at inspection. - DonRotolo [more]
Unread 30-09-2012, 14:28
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Running chains on zipties
We have a little problem with our robot: since we have a gap in the frame, we added a support beneath the robot, connected to buth inner and outer c-channels on both sides (we have a kitbot drive). Up to this point everything is pretty with unicorns and sunshines.
The problem is it's now passing between two wheels connected by a chain. The chain is a bit loose and brushes against the support. We don't have enough room for an AM tensioner (http://www.andymark.com/product-p/am-0286.htm), and we couldn't find anything small enough to fit yet strong enough not to break.
I thought of wrapping a bunch of zipties on the support, parallel to the chain's movement direction and have it run on them.
Questions are two:
  1. Will it work? (Sub questions: how well? Will the zipties give? Will it preserve more energy than letting it run on the support? What would harm the chain more? etc.)
  2. Got any better ideas? We would very much appreciate some.
The chains are #35 series and the support is an aluminium square profile.
BTW, feel free to discuss a theoretical, unrelated secnario of chains running on zipties
Unread 30-09-2012, 14:39
Re: Running chains on zipties
Delrin or UHMW. Get a small, flat piece, maybe a little bit too thick for the chain. Bolt it to the support and run the chain over it. The chain will probably wear into the Delrin or UHMW a bit; this is OK, it's just tensioning itself.
Unread 30-09-2012, 16:40
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
While not ideal I have seen teams use HDPE as well, usually sourced from an old cutting board.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 30-09-2012, 16:55
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Delrin would be ideal but if you don't have any, grab some small diameter PVC and split it down the middle and attach.
1058 PVC Pirates 2016 - xxxx
Unread 30-09-2012, 19:09
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I saw I team use this at 2011 SVR. I forget what team in particular, but when I asked them about it, they said it ran great and never failed on them. As far as I can remember, it was 35 chain. I've heard of other teams using it without problems as well.
Try it, and it it works, great. If it doesn't, try some of the other suggestions in this thread. There's nothing wrong with experimentation.
-Plutarch
Unread 30-09-2012, 19:10
bardd's Avatar
That loud guy
AKA: Bar Danino
What's "it"?
Unread 30-09-2012, 19:13
AKA: Brendan Browne
If you can get a picture of this area, it would be extremely helpful in offering advice!
Unread 30-09-2012, 19:15
bardd's Avatar
That loud guy
AKA: Bar Danino
I would, but by the time I get to the robot there will be no point asking. You see, our next (and last with this bot) competition will be Wednesday, and we won't get to work on our robot until Tuesday.
Unread 30-09-2012, 19:16
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by bardd View Post
What's "it"?
Tensioning the chains with zip-ties.
-Plutarch
Unread 30-09-2012, 19:18
bardd's Avatar
That loud guy
AKA: Bar Danino
Oh... Great, thanks.
Unread 30-09-2012, 19:21
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
In which direction does it hit the support? Top or bottom of the chain? Like many other individuals have suggested, delrin would be the best bet for this application.
After doing a bit more further reading, it sounds like it is hitting the bottom. Encompassing the delrin solution, I would personally get a nice uniform 3/8" block of any nominal length and tap for 1/4-20s while fastening from the top of the frame. Also, round the edges on any belt/disc sander to give a nice profile so that way the chain isn't hitting a 90* edge.
If you guys could provide a picture as well, this would help eliminate the problem completely!
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 30-09-2012, 19:38
PhantomPhyxer PhantomPhyxer is offline
FRC #2643
PhantomPhyxer is on a distinguished road
I would also recommend Delrin. It is sold by Mc Master Carr in several shapes. We are currently using Derin on our 2012 Robot for Chain Guides. Just make sure you have plently of rap on your sprockets.
Unread 30-09-2012, 19:48
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
We usually take those AM tensioners and drill a hole through the nylon pieces and just bolt one half (as in one nylon piece) to the frame somewhere along the length of the chain. I wasn't able to find a better picture of it but you can see the top of the piece in between the 2 middle wheels.
About the zipties, we have actually used them as tensioners before in very desperate situations (like at a demo when we forgot everything else) and they work for a very very short time before the chain cuts through them. We have however had chain run against metal (1/4" bolts) before and it usually is fine.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 30-09-2012, 20:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We used some pieces of ABS sewer pipe to tension the chains on our 2011 robot, easy and it worked well (until the axles bent but that's a story on another thread). Kind of like the PVC pipe suggestion.
Good luck!
Unread 30-09-2012, 20:43
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
zip ties will find a way to pop off the master link.
My Instructables
