Go to Post I once heard someone say that Dean is "building an army of engineers." I disagree. I think he is building an army of the informed. - Gope [more]
Unread 30-09-2012, 19:48
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: Running chains on zipties
We usually take those AM tensioners and drill a hole through the nylon pieces and just bolt one half (as in one nylon piece) to the frame somewhere along the length of the chain. I wasn't able to find a better picture of it but you can see the top of the piece in between the 2 middle wheels.
About the zipties, we have actually used them as tensioners before in very desperate situations (like at a demo when we forgot everything else) and they work for a very very short time before the chain cuts through them. We have however had chain run against metal (1/4" bolts) before and it usually is fine.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 30-09-2012, 20:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We used some pieces of ABS sewer pipe to tension the chains on our 2011 robot, easy and it worked well (until the axles bent but that's a story on another thread). Kind of like the PVC pipe suggestion.
Good luck!
Unread 30-09-2012, 20:43
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
zip ties will find a way to pop off the master link.
My Instructables
