Thread Tools |
Rating:
Display Modes |
Re: Shop Tools, Hand Tools, HELP?
Just one other thing I just thought of...
do you have a local technical school near you? You might be able to partner with them and they might be willing to help you guys out with machining of parts and welding. This is where you might also find access to a nice printer or computers. F22Rapture bringing up community colleges made me think about it. |
There's a pretty nice 3d printer in our school's Engineering classroom...we've had Engineering students on the robot team for a few years...and we have yet to figure out a robot part that we could print with it. I would look at other things to spend money on.
It sounds like you need put in some "shop class" time before you get too far along buying tools. Knowing how to use them is vital. |
Saw this and had to comment: Skyhook's intake roller had a pair of hubs that came off a 3D printer, complete with the "standard" 6-hole bolt pattern. And the box containing Skyhook's IMU came off the same printer. And at that point, we'd had the printer about a month, maybe 2. When I was in college, we got some plugs for a robot's frame built on their high-quality one.
If you're stuck for space and/or cash, you might consider a combo mill/lathe/drill. It won't do any of these tasks as well as the individual tools might, and it's small (but so, relatively, are the robots), but it wouldn't take up too much space and would at least provide you these capabilities at a lower cost than the individual machines.
I think that there are other teams who use one of these as (one of?) their primary machine. A quick google search ("combo lathe mill") will show you a number. From what I've read, there's basically a price/quality relationship. The more you pay the better the tool, so, if you go this route, buy the best you can afford. |
#7
If you're looking for larger machines, try industrial auctions. We picked up a Bridgeport in good condition for ~$750 including vice and a set of R8 collets. Just watch your voltages as many industrial machines are 600V. To meet school regualtions, we have to install a magnetic swtich as well and fix up the guarding.
#8
A low cost metal bending brake plus an inexpensive shear would be worth considering if you have a table to mount them on. Bent sheet parts are useful in lots of places. You can get both at Harbor Freight for a combined $200.
#10
Agreed. A tool you don't know how to use is functionally useless.
#11
At best. Just as often it's a liability to your work or your safety.
#12
Many products from RIGID come with lifetime warranty on everything including batteries....
I'm not sure if this has been added but a good tap and die set is something great to have around |
#13
There should be a number of threads out there with a lot of the information you're looking for. I'm not sure if they have information on specific models of tools though.
3 in 1 machines are junk. Avoid them like the plague. You're basically throwing money out that you could save for quality machinery. I would not purchase corded drills. The technology is such in cordless drills that there is no reason to purchase corded. We got rid of a corded drill we had because it had so much torque it was unsafe for inexperienced users. You really don't need a sliding miter saw. We have this. $200 and it works great. High quality. Throw a nice carbide tipped blade on there and you can easily cut aluminum tube (absolutely do NOT cut solid/ferrous metal with any miter saw). We purchased one of those 20 ton presses like mentioned earlier, used it for a year, and then gave it away. It's super inconvenient due to the limited travel of the bottle jack, as well as slop in the ram because of the construction method. I would see if you can get the sponsor to just grant you the money, as opposed to them purchasing tools off a list. It makes more sense to add tools as you discover you need them, instead of trying to cover everything up front. Inevitably you will end up with a lot of tools you rarely/never use if you do the latter. As soon as you cover your basic tool needs and are looking for machine tools I would purchase a lathe. |
#14
Have you considered a second drill bit set and a drill bit sharpener? They may seem unnecessary but with drill bits many students tend to break them and leave them laying around. Leave one out and one kind of hidden away for that moment when you need that one size bit.
Furthermore with many tools being used bits tend to get dull and there becomes a collective pile of dull drill bits which tends not to be to fun to deal with. These aren't necessarily but useful none the less. |
#15
The storage thing is something that you'll have to decide, but what I would do is be able to bring as much of the stuff as you can. That means portable toolboxes, rolling or not, that you can take out of the shop and stick in a vehicle. One set of tools probably isn't going to be enough at the competition. Bring 3. That's also where the KOP bins come in; they stack nicely under a table. When I was on a college engineering competition team, about the only thing from the shop we didn't take to competition was the workbench--we brought folding tables in the trailer instead. Figured if we didn't need it, someone else did. Gray, I think you've got it reversed. I know of teams who've gone years with a miter/chop combo saw and no vertical bandsaw--about the only thing it can't do is turning cuts. That's why I put a Dremel (OP, take note--I'd put that at a 1 and it's fairly cheap) on the list, as it's a highly versatile tool that can help with making turning cuts. The Bridgeport instead of a drill press--Sorry, but a used Bridgeport can run in the $2500-$5000 range and that's without tooling. A 2-axis vice for a drill press can give some mill functionality; you just have to go slower when cutting a slot. And like I said, without knowing how much space they've got available, I'm willing to bet that a mill will take up an awful lot of it. |
