Go to Post And then the judges joined in and did the wave! - Basel A [more]
Unread 14-01-2003, 10:30
Raz Raz is offline
Raz is an unknown quantity at this point
Pneumatic settings
Is it possible to get the pneumatics to extend to a certain amount from each click of a joystick? Our team wants to have 4 settings for the pneumatics, obviously 2 are the fully contracted and fully extended modes, but the other 2 are in the middle, is it possible to do this? and if so how?
Unread 14-01-2003, 10:43
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I know it can be done, though I can't remember how right now. I would suggest searching past threads (it's come up before), but if I find something, I'll let you know. It is possible, though.
Jeff Waegelin
Unread 14-01-2003, 11:20
PyroPhin's Avatar
PyroPhin PyroPhin is offline
None #0263
PyroPhin is on a distinguished road
it definetly is possible, i dont know how accurate it is.. but our team has done it in the past.
it basically consists of attaching another solenoid to the exausts of the one controlling the piston you want released. you energize the primary one to either bring the piston in or out, then momentarrily tigger the one attached to the exaust untill you find your desired length.
as for the actual indexing... the only suggestion i can think of is put a pot on whatever your moving with the thing and get a reading off of that, or mark the actual arm (like this | | | )of the piston and use an optical sensor to record the ammount of lines that have passed. that would give you a somewhat accurate reading..
~Pyro
Squee!
Team 263, Aftershock:
Alumni, guy who comes back and fixes Krass's mistakes
Unread 26-01-2003, 15:33
jon virgi jon virgi is offline
#1191 (Eagles)
jon virgi is an unknown quantity at this point
Send a message via AIM to jon virgi
how would you program the valves to do what they need to do, and also if you are using the 2 valves on the one cylinder then would you use one or 2 of the spikes?
Keystone Oaks Robotics Team President / Webmaster / Lead Pneumatics designer / Lead electrical........
Unread 26-01-2003, 16:54
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Routing the exhaust of the double solenoid through the single solenoid works well. Just put a stop on one of the single solenoid outputs and leave the other open. When the solenoid go to open air the cyclinders will move, but will stop when you switch to the stopped one. I don't know about stopping at intervals yet because we were looking into it as for more control of the cyclinders.
Unread 26-01-2003, 18:25
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
If you are using this to both launch and stack boxes (extend halfway to stack, extend fully to launch) you could take a different approach to stacking. The way we are planning to do this is to have a screw-jack under the arm we"re launching the boxes with, so we can lift the arms slowly and thus either stack boxes or run around with a box before launching it. We are then going to use a piston to launch it, but we won"t need to have the piston have two actuated positions.
Unread 26-01-2003, 21:59
#1191 (Eagles)
well, we arent going to launch the boxes but grab them using the cylinder to close on them but since it could be grabbing the 24 inch side or the 17 inch side, we need it to be able to stop at two positions.
Any more info on this would be great, especially on programming the stoppping settings. and any info for the wiring of the valves for this setup.
Unread 03-02-2003, 20:29
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
If your cylinder is small enough, you could just have it close all the way, and the box will keep it from closing all the way on the 24 inch side.
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 03-02-2003, 20:38
_-GoMeZ-_ _-GoMeZ-_ is offline
_-GoMeZ-_ is an unknown quantity at this point
Yep it's possible
See thread "Can you stop a pneumatic pump at half shaft" I posted a solution there.
Hope it helps
Good luck !
Who has used pneumatic wheels? chellyzee93 Kit & Additional Hardware 3 16-02-2003 11:49
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
pneumatic confusions someone from FIRST please respond Greg Needel Pneumatics 4 17-01-2002 22:28
