Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
  #31   Spotlight this post!
Unread 01-10-2012, 22:51
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: WCD vs Standard
Also, can you weld the AM Flanged bearings to standard aluminum wall? (6061 I think).
I am pretty sure that those bearings are steel not aluminum, so welding them to aluminum isn't really possible (As far as I know). but anyways, there are far easier ways to mount bearings than welding them, as Mark already said they can be pressed in or super-glued. On our robots we usually hold the bearings in with a screw and washer that covers part of the flange.
The smaller wheels allow for smaller gear ratios and sometimes fewer reductions in the gearbox, this usually results in a more lightweight gearbox. I do not know about keeping the wheels as far out as possible as a motivation for smaller wheels, I would usually try to do that anyways regardless of wheel size (just my preference no real reasoning on my part behind it).
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #32   Spotlight this post!
Unread 01-10-2012, 22:56
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: WCD vs Standard
Originally Posted by Gregor View Post
Smaller wheels will in fact make the robot go slower at the same gear ratio. Wheel size shouldn't be considered in terms of speed, as you should be adjusting your gear ratio to account for the wheel size. However the 4" wheels will save weight and widen your wheelbase, as opposed to 6" and 8" wheels.
Typically, teams press fit bearing, as opposed to welding them.
So you do want to put your smaller wheels farther to the outside, to widen your wheelbase? Putting them in the same spot you would put an 8in wheel would be pointless, I am assuming, because the wheel base would be the same, but you wouldn't get better speed?
And what is "press fitting"? Could you elaborate.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
  #33   Spotlight this post!
Unread 01-10-2012, 23:00
Garret's Avatar
AKA: Garret Smalley
Re: WCD vs Standard
Press fitting usually means (at least how I have interpreted it in FRC) the hole is slightly undersized such that the bearing needs to be pressed in quite hard, this will result in a tight fit that will hold the bearing in place.
7 Years of FRC
  #34   Spotlight this post!
Unread 01-10-2012, 23:06
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: WCD vs Standard
Don't weld or weld near bearings. The grease has a bad habit of lighting on fire.
You need less gearing for 4" wheels though, and they have a lower mass (and therefore moment), so it can save you weight even if you don't put them further out on the frame.
Press fitting refers to having a hole that's just slightly smaller than the diameter of the bearing, so when you press it in, it doesn't come out. It's kind of tough to figure out what size hole to make and then make it accurately (within a few tenths).
  #35   Spotlight this post!
Unread 01-10-2012, 23:07
UAH Class of 2019
Re: WCD vs Standard
Well, good thing I asked, thanks!
  #36   Spotlight this post!
Unread 01-10-2012, 23:21
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: WCD vs Standard
Ok, multiple things:
1. If you need to hold in a bearing that is not a press fit the standard approach is to use bearing loctite, not glue or welding. Although glue is a much better idea than welding. But why are so keen on holding in your bearings?
2. A press fit is not necessarily undersized, it could also be exact size. The difference between press and slip fit depends on surface finish as well as hole size. If you have a hole that you made exact size via a rat tail file chances are that's not going to be a slip fit. I caution you if you press in your bearings, too tight a fit can make a bearing seize up.
3. I would not suggest having a drivetrain with swap-out wheels with the size variation that you're talking about. If you have clearance for a 8" wheel but you use a 4" you're just not utilizing your frame space, the idea is to get the wheels close to the ends of the frame. There is no way you can swap out a 8" wheel with a 4" without changing the gear ratio. The fact that you want to do this makes me think that you didn't fully plan out your ratios and wheel sizes to your desired torque/speed. I suggest you calculate your drivetrains speeds using your different wheel sizes and you'll see how big of a difference wheel size makes.
4. The advantage of small wheels is that they're light, they lower your CG and they require less reduction. Don't use them unless you calculate your robots speed using them, or you might end up with a very slow bot.
  #37   Spotlight this post!
Unread 02-10-2012, 00:19
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: WCD vs Standard
Originally Posted by JosephC View Post
To my understanding, A live axle is one that supports part of the weight of a robot and drives the wheel(s) connected to it. A dead axle is one that carries part of the weight of a robot but does not drive the wheel(s). The wheel(s) rotate on the end of the dead axle.
Live axle = Axle turns, wheel is keyed to the axle.
Dead axle = Axle is fixed, wheel turns on the axle.
  #38   Spotlight this post!
Unread 11-10-2012, 21:00
UAH Class of 2019
Re: WCD vs Standard
So, doing more research on CD, I have come across bearing mounts called "Sliding Bearing Mounts". What are these exactly. It seems as if they are used for chain tightening, but I have no details about how they do this.
  #39   Spotlight this post!
Unread 11-10-2012, 21:58
Aren Siekmeier's Avatar
on walkabout
Re: WCD vs Standard
Many teams build bearing blocks for their drive train which hold the bearing and axle. This bearing block can slide forward and backward in the frame (moving the wheel with it) in order to adjust chain or belt tension.
Unfortunately, 254's website is under construction, so I can't pull up any of the great pics I know they had there. I'm sure someone else here can dig up some instructive photos.
  #40   Spotlight this post!
Unread 11-10-2012, 22:03
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: WCD vs Standard
The "Sliding Bearing Mounts" are blocks that house the bearings for the live axle and they slide in slots in the frame. This allows you to move the axles slightly further appart tensioning the chain.
  #41   Spotlight this post!
Unread 11-10-2012, 23:02
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: WCD vs Standard
It's interesting to hear so many people say that canilevered, direct driven systems are the lightest and best when some of the most successful teams in the world do neither of those things (most notably 67 and 1114).
I know Jim Z has done annalysis on 254, 1114, and 67's frames. I *think* 1114's frame was lighter than 254's by about two pounds.
We used .06 sheet metal this year and will probably go down to .05 sheet metal next year. I am pretty sure that our frame weight beats out 254's by a pound or two. What get's 254's weight so far down is there use of tiny wheels which takes weight out of both their gearboxes (which are custom and very light) and wheels (also custom and very light). Direct diving helps too I'm sure.
Perhaps, some 254 people could chime in and correct me here if I'm wrong on any of these points?
In any case, I'm just stirring the pot.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
  #42   Spotlight this post!
Unread 11-10-2012, 23:09
Re: WCD vs Standard
For the best example of a well executed sliding bearing block I would strongly suggest downloading some of 973's CAD models.
  #43   Spotlight this post!
Unread 11-10-2012, 23:31
Gray Adams's Avatar
Re: WCD vs Standard
The idea is that the wheel, axles, sprocket, and bearings are all part of a block that slides back and forth along the chain path to adjust tension.
Here is a section view from our offseason project last fall. If you look carefully inside the tube, you can see the space the bearing block has to slide back towards the gearbox and loosen tension (to the right).
Also, here's a view of how we kept the bearing block in place. http://i.imgur.com/VrDEJ.png
It worked, but it really wasn't the greatest method. It should get you thinking though, and we came up with it halfway through building it.
  #44   Spotlight this post!
Unread 11-10-2012, 23:48
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Re: WCD vs Standard
I will side with the live axle cantilevered drivetrain not on the grounds that it "weighs less", but by the fact that maintaining one can be easier. When the wheel is supported by live axles on both sides by the frame, working on the drivetrain becomes easily more painful and irritating when frame members are in the way. With the average west coast drive, replacing components like wheels, axles, and chain is a snap because there's only one frame member to deal with.
  #45   Spotlight this post!
Unread 12-10-2012, 00:18
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: WCD vs Standard
I can't find a good picture of the bearing blocks themselves, but here's a shot of the rectangular holes in the frame where they go. You might get a better idea from browsing the rest of the 2012 build season album. Basically, there are two halves that come in from either side of the rail and fit inside each other, each having a bearing pressed into it. Long bolts through the rail are used to hold the two halves together, and there's a cam mounted to the rail that is torqued once the chain is installed to push the block which tensions the chain.
I wouldn't say that weight is the top factor in 254's choice of using a cantilevered drive year after year. It probably only comes in fourth after ease of maintenance, robustness, and aesthetics (you wouldn't believe how many design decisions come down to aesthetics).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
