Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 14-01-2003, 11:26
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
UpDate #4 Is Out
Haven't gotten a chance to read it yet, but #4 is OUT!
EDIT: Just read it over and it seems like a multiplier stack has to be a continuous stack of bins, touching the floor up to the top. No virtual stacks. HURAH!
Unread 14-01-2003, 11:34
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Edit your posts.. and we can read for oursleves.
Unread 14-01-2003, 11:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
They changed Rule M17, so that's good.
But, come on. . . distance from the floor to underside of the barrier is 14 5/16" +/- 1/2" ?!?
That's a little ridiculous.
--Madison--
...down at the Ozdust!
Unread 14-01-2003, 11:39
Joe Matt's Avatar
Your kidding me. That's rediculous. You design a robot and then FIRST has an inadequate feild set up so it dosn't work. Great, just great.
Unread 14-01-2003, 12:04
FRC Key Volunteer Trainer
AKA: CrazyNate
Hey, if you look over the blueprints for previous years, you will see that in the past, they have always said a tolerance of +/- 1 inch. So they're getting a little bit better...
Nate Smith
nsmith@smythsoft.com
Unread 14-01-2003, 12:28
Jason Morrella Jason Morrella is offline
Robotics Education and Competition
AKA: J-Mo
no team (RECF)
Jason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond reputeJason Morrella has a reputation beyond repute
I don't think you have to worry about the distance being different at every event. The FIRST fields will all be built to spec: 14-5/16". So at most or all events, that's what it will be. What FIRST can't control is if a given venue does not have a hard floor or cover for their floor (almost all do) and instead puts down a soft/foam layer on the floor under the carpet - in which case the field could possibly "sink" a little and affect that distance.
In general you can count on the distance being 14-5/16". I think they are just trying to cover themselves and be honest with all the teams - that it would be wise to give yourself a little room.
Even without this update, that's good advice - it's always good to give yourself a little safety room just in case the field you're on is not EXACTLY to spec. Personally, any team I speak to, I advise them to always give AT LEAST 1/4" on their frame and field measurements when designing (e.g. I wouldn't build the frame to exactly 30x36, and I would build an "under the bar" bot higher than 14" tall - just to be safe. But that's just me)
Not sure if that helps at all - just wanted to clarify that it's more of a "venue" issue than a "FIRST field" issue.
JM
Unread 14-01-2003, 12:59
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
hey does anyone know if the use of a microcontroller is permitted. the update said that the cannot be more than one control SYSTEM so does that mean you can use one or can't you? It seems to me that this would mean that it must be used with the robot's controller, but not separately. Let me know what you all think.
thanks
Unread 14-01-2003, 13:03
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Like Jason said, you should always give yourself some room when you are designing a robot... It NEVER make sense to design a robot that will work exactly according to specs...
You never design a big ball robot that can put up balls exactly to the height of the goals, you always add a little bit height so you can put the ball above the goal and make your drivers' life easier that way... Same thing with the moving goals last year... Even if you know the bottom pipe's diameter, you always design your claw to be a little bigger so you can account for drivers' error.
It is just good practice to design something with a torrence for error, in case something bad happen during the game. Maybe your robot was hitted during the competition, and suddenly grew a quarter of an inch in height... OR maybe something was left on the ground, and suddenly your 14 5/16" robot can't go under the bar with a bolt stuck under your wheel.
Minus half an inch is a small number to work with... And remember, the 1/2" goes the other way too... The bar might be taller then you think.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 14-01-2003, 13:08
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
I think you should sorry about designing a robot for more than 1/2" of difference because in my experience, FIRST fields are usually off from competition to competition. The bars, lines and field barriers are all subject to be moved by robots during the game and they may be slightly off in the first place. The problem usually gets worse as the competition progresses. The bottom line is you should keep these inconsistencies in mind in the same way you should take differences in scales into account.
Unread 14-01-2003, 13:21
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Yay, we can add timing belt to skyway wheels again!
I guess the debate about CNC Flames vs Lightningbolts for the sides of our custom wheels is over.
Unread 14-01-2003, 14:16
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Maybe I am reading too much into this, however the update to rule M17...... deviced such as anchor surfaces are not allowed on the ramp or platform. Will this affect certain suction devices?
Unread 14-01-2003, 14:32
Dare to Live!
"Please delete this sentence; however, now we need to address the issue of “anti-traction” devices or anchors, i.e., devices designed to hold you firmly in one place. Anchors cannot
use metal in contact with the carpet to “stay put.” Similarly, metal traction or anchor surfaces are not allowed on the ramp surfaces."
I believe the spirit of the rule is to prevent teams from using something metal to dig into the playing field, and anchor themselves onto the top of the ramp. They specifically say "anchors cannot use metal in contact with the carpet to "stay put"." So, anchors that are not made with metal, such as a plastic suction cup should be allowed, as long as they do not damage the playing field.
Unread 14-01-2003, 14:34
AKA: J-Mo
no team (RECF)
Actually - it doesn't say these devices are not allowed.
It says METAL devices (traction, anchor, wheels, etc.) are not allowed to interact with the ramp or platform or carpet.
So - such devices are allowed as long as the metal is not touching the playing field (carpet, ramp, platform) and the devices can't damage the playing field in any way.
Unread 14-01-2003, 15:57
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Boiled down: NO FILECARDS!
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 14-01-2003, 18:18
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Heh. In 2001, we asked FIRST for the height of something on the playing field, and we got the response, "It is exactly x", +/- 1.5"
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Powerbook update? evulish Chit-Chat 1 01-08-2003 18:48
Update 11 is up Katie Reynolds General Forum 3 06-02-2003 21:36
when's update #4 coming out? BBFIRSTCHICK General Forum 7 13-01-2003 09:15
Update 3 is up Jay5780 General Forum 1 10-01-2003 17:43
Update #3 is online archiver 2000 0 24-06-2002 00:22
