Go to Post unless your team is incredibly beastly, completely ignore the words "cool factor". Coolness does not outweigh functionality. - Sam N. [more]
Unread 02-10-2012, 17:23
tyandjel94 tyandjel94 is offline
FRC #1647 (Iron Devils)
tyandjel94 is an unknown quantity at this point
Power Function
I was wondering the best way to make a power function for any number. I came up with the conclusion of using Newton's root finding Method which computes is a method for finding successively better approximations to the roots (or zeroes) of a real-valued function. I was able to find that this worked perfectly on a calculator, but it didn't work when you program it. This is because the long, double, and float data types are not long enough. A bigDecimal is needed, but the FRC Java which is Java ME doesn't not have that class. Is there a way to work around this? Thanks a lot.
-Tyler
Team 1647 Iron Devils
Unread 02-10-2012, 17:44
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Power Function
Isn't there already a power function in Java.lang.Math?
http://docs.oracle.com/javase/1.5.0/...e,%20double%29
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 02-10-2012, 17:48
Re: Power Function
Yes in regular Java but not FRC version. Also in regular java its function is native so the class has no copyable code.
-Tyler
Unread 02-10-2012, 17:52
Re: Power Function
I suspect you did not program it correctly. Double precision floats should have adequate resolution for this.
But there may be a better way. Does the Java FRC runtime math library support logarithms and exponentiation?
If so, there's a simple solution:
You want to compute:
power = base^x
... for any positive real base and x, correct?
To do so, substitute e^ln(base) for base to get:
power = e^(x*ln(base))
Unread 02-10-2012, 18:05
Re: Power Function
No it doesn't have log or exponent functions. And no the number of precision has to be more than the max value of double (1.7976931348623157 *10^308). If it's not then the program keeps running down to the base value, then get a runtime error.
-Tyler
Unread 02-10-2012, 19:06
Re: Power Function
http://www.chiefdelphi.com/forums/sh...63&postcount=4
Originally Posted by Jared341 View Post
Most of the underlying math primitives (e.g. forward and inverse trig, exponents, square roots, etc.) are present in the FRC Java implementation - they went ahead and implemented more than the bare bones J2ME spec requires (albeit in a different package structure than J2SE...you need to do some digging to find where some of the classes live)
Unread 02-10-2012, 19:48
Re: Power Function
Ok thanks. I found it under squawk. Do you know if there are arrayLists, decimalFormat or java.net classes? Thanks again for your help.
-Tyler
