Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
Unread 02-10-2012, 16:32
AKA: Dr. Brooks
no team (WRRF)
Starting FMS Light (2009) so it does not contact the server
FMS Light (2009) looks for a server connection to check for updates the first time it is started after installation. There are flags for a command line start, using the run function on Windows XP, that prevent it from doing this. I used them at an off-season even one year, but have lost the information about them. Does anyone know what they are? It is important now that the server is off-line and the first start will hang looking for the server.
Eugene
Unread 02-10-2012, 16:52
Re: Starting FMS Light (2009) so it does not contact the server
I don't remember the flags, but if it helps here is an earlier version that did not perform the manifest check at all. The drawback is there is no Audience screen.
http://team358.org//files/programmin...ight-358XP.zip
Unread 02-10-2012, 23:09
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
We used FMS light for our off season, and we simply ran it once in the shop with a connection before taking it to the field. It would still try to connect but it would time out and continue. Just make sure you launch both the FMS and audience programs while online.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 02-10-2012, 23:21
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
you could just put a help flag, and tell cmd to list all the possible flags. Sometimes putting a garbage flag "-sdsfd" works too, but I wouldn't recommend it.
Unread 04-10-2012, 18:22
kmitchell kmitchell is offline
kmitchell is an unknown quantity at this point
Unfortunately connecting once isn't currently possible in this case since the server FMS light is trying to connect to is currently offline. FIRST has been made aware of the problem and is working to get the server back online. In the meantime if someone who has a working FMS Light setup could send me the "manifest" .xml files contained in "C:\Program Files\FIRST\Launcher" I could test a theory that I think we could use as a workaround.
Unread 04-10-2012, 18:27
This assumes that some type of help feature was available. The launcher shell appears to just ignore flags it doesn't recognize. I did see some interesting things but nothing successfully started the program.
Unread 04-10-2012, 19:00
timytamy's Avatar
AKA: Tim
This is my entire P:\Program Files (x86)\FIRST\Launcher folder.
Tim W
Sydney, Australia
