Thread Tools |
Rating:
Display Modes |
Re: Advantages to a long bot?
Advantages and disadvantages of different robot configurations vary largely depending on what that year's game is. Long robots provide more stability when accelerating. They also allow for more wheels. They are easier to drive over a barrier or up an incline because they are less prone to tipping.
Again, though, it depends on the elements of the game. |
Long bots are more stable overall. Some think they are easier to drive. Stability is key in FRC-- I often see robots much taller than they need to be driving around. You can almost never go wrong with a low center of gravity. Making your robot wide requires that CoG to be lower to retain stability from tipping.
We have only gone wide when the game called for it. This years game called for it in two ways; wide was smaller on the bridge and wide for a larger ball pick up area.
Long robots are able to fit through smaller gaps. In my experience it was harder to defend a long robot than a wide one.
Longbots are inherently more stable in the forward-backward axis. Thus, they can accelerate and decelerate quickly with less sway. Consider also that if you're crossing a barrier, like this year, a longbot would be far less likely to flip while crossing it perpendicularly. Since you're much more likely to experience instability in the forward-backward axis than the side-side axis during an FRC match, longbots are generally the better choice.
However, there are a few scenarios in which a widebot configuration might be beneficial. This year, if you didn't go for an over-the-bumper solution for ball capture, a widebot would have provided quite a bit more room for balls picked up. In pushing or highly defensive games, a widebot would provide a slight traction advantage and can turn a bit easier. Usually though, speed is more useful than pushing power, and stability more than ease of turning, so the longbot comes out on top. A properly-done West-Coast Drive can negate several of the advantages of a widebot while also coming out ahead in speed. |
As a driver, my favorite bots to drive were long bots because ours didn't turn in a circle as fast. This helped refine control of the robot so when we went to a wide base for this year it wasn't that hard to control.
Peyton |
#7
How so?
#8
Not really game related, but long bots are easier to get through door ways.
#9
In all honesty my team has only ever made long bots, after our rookie year. We like them more since it is easier to control for a driver, you can fit more wheels in a standard drive, and when we tried a wide bot with mecanums it responded weird when driven diagonally (this could have been our programming but we just didn't like it). One year where I think it was really good to use a wide bot was 2009 since it made it much easier to pick up moon rocks.
#10
Traction is probably the wrong word, but it's easier to deflect the force of a longbot than it is a widebot, and most longbots have drop-centers so depending on the wheel types (some teams like to put omni's in the front) and whether or not it's 6wd or only has the back 2 sets powered, a longbot on a drop-center pressed up against another robot may or may not have the same footing that a widebot which usually wouldn't have the drop-center would have.
[edit] that was a terrible run-on sentence Last edited by F22Rapture : 03-10-2012 at 21:20. |
#11
Drop center longbots wont be effected if they are hit from the front or back, but yes they could "spin out" if it from the side, due to the shorter wheelbase. What does Quote:
#12
This was mentioned earlier but not explicitly stated. long bots will turn faster than a wide bot.
#13
One of the things that makes a wide bot hard to drive is the fact that it turns so quickly. |
#14
Quoted for truth
#15
a) Is "Turns too fast" really a legitimate reason not to do a wide bot? That is so easily fixed in code. Even if you dont want to loose any control throw, throw some exponential rates in there for some fun.
b) For this year, we found long bot beneficial as it was basically impossible for us to tip backwards when going over the bump even though we didnt have a low center of gravity. Wide would have been a different story. |
