Go to Post Conspire to Inspire despite what may transpire ! - Bill_B [more]
Unread 03-10-2012, 22:40
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Success with encoders
We have had some problems with getting an encoder working on our robots. Our team stood up in 2011 and it wasn't essential to have an encoder for Logomotion but it was a critical part of a successful shooter for Rebound Rumble.
The problem we had with the Kit of Parts encoder was the shooter RPMs being up in the 1000+ range, there were some vibrations that were causing the encoder to misread the encoder disk. I wanted to see if other teams had experience a similar problem.
Also, for the teams that don't use the KOP encoder, what type of encoder are they using?
thanks,
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 03-10-2012, 23:14
Re: Success with encoders
I've always liked using enclosed models like the Grayhill 61K, 63K/R (example) (spec sheet: ShaftEncoder_128CountPerRev.pdf) .
A 63R is guaranteed for 10 years of continuous use at 5000rpm. We're still running them on a robot from 2004.
For drive train or shooter type applications look for encoders with a high rotational life, ball bearings, etc.
Lighter duty applications can use cheaper alternatives by using bearing sleeves, lower rpm ratings, etc.
Depending on the application you might consider absolute or incremental, quadrature, BCD, etc.
Both digital and analog models are easy to deal with and the FRC cRIO is setup to handle them. Other connection methods (I2C, SPI,) tend to cost more. PWM outputs don't really work with FRC without the added complication of custom circuit pre-processing.
Do be careful to match the counts-per-revolution to the application and the capabilities of the cRIO to handle the maximum counts-per-second you design for.
Unread 03-10-2012, 23:20
http://www.chiefdelphi.com/forums/sh...04&postcount=2
Unread 04-10-2012, 12:44
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Originally Posted by Mark McLeod View Post
I've always liked using enclosed models like the Grayhill 61K, 63K/R (example).
How do you typically incorporate these encoders into your robot? gears, timing belts, etc? Pictures would help.
Thanks.
- T
-T
Unread 04-10-2012, 12:54
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We are currently using an KOP encoder in our off season robot, so far it has been working mostly. Our problem is more so our PID code..
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-10-2012, 13:21
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Analog models are easy to deal with and the FRC cRIO is setup to handle them. Other connection methods tend to cost more.
Where is the like button?
I prefer the greyhill's. They work well with kids that my not understand the robustness of the KOP encoders.
Unread 04-10-2012, 14:54
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
We used the KOP encoders for our shooter which ran up to about 4500RPM without any issues.
In years past when encoders weren't in the KOP we used the "H" series from USDigital with good success.
http://www.usdigital.com/products/en...otary/shaft/H1
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 04-10-2012, 15:50
Mk.32's Avatar
AKA: Mark
Is there documentation on how to wire/program an Analog encoder such as an greyhill?
Unread 04-10-2012, 16:08
Several different ways.
You just have to avoid side loads on the encoder shaft, so usually we use an L bracket to hold the encoder and a flexible coupler, e.g., a short segment of pneumatic tubing, as a coupler directly to a shaft, as if you were replacing the KOP encoder on an AndyMark gearbox.
We've also used a hardware shaft coupler available from McMaster and elsewhere.
Here's a photo of a mount (from our 2004 robot) using plastic gears to couple to a drive train.
We've also used a sprocket w/ #25 chain on a special purpose turret. The sprocket has to be supported at both ends on a separate shaft, so the encoder doesn't carry any load.
The Grayhill model I mentioned is a digital input. (I went back and reworded a little to avoid that implication)
Here's an example of an analog encoder with 10-bit resolution that's rated for 20,000 rpm. It is terribly expensive (but under the FRC $ limit), so I wouldn't recommend it. But it'll give you an idea of how simple the wiring and use is.
The wiring pinout is on page 12.
Unread 04-10-2012, 16:29
Mk.32's Avatar
AKA: Mark
You just have to avoid side loads on the encoder shaft, so usually we use an L bracket to hold the encoder and a flexible coupler, e.g., a short segment of pneumatic tubing, as a coupler directly to a shaft, like you would to replace the KOP encoder on an AndyMark gearbox.
Oh my bad, then could I just use the encoder class built into the JAVA api to run it?
Unread 04-10-2012, 16:46
Yes, that works seamlessly with a Quadrature output-type, like the Grayhill 63R.
Unread 04-10-2012, 17:14
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
It is absolutely critical that run out be very small and end play in the shaft be near zero. The distance the encoder wheel is set from the sensor is very important. You need to look at the signal with a scope. If everything is not just right the sensor will drop out one or the other of the A or B channel. This creates errors. It is important that the sensor base is used with the correct line count encoder wheel. If the two do not match then the relationship between the A and B signals will not be 90 degrees.
We mounted a KOP sensor on the CIM motor for our drive train. It was reading in the 4800 RPM range just fine once we got everything aligned properly. Attached is a photo.
We used the larger brother of the KOP sensor for the shooter. We used a 3/8" shaft. The sensor is larger, and seems easier to mount. Attached is a photo with the cap removed. Here is a link:
http://usdigital.com/products/encode...rotary/kit/E7P
-Hugh
ID:	13067  Click image for larger version
Unread 04-10-2012, 17:37
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
US Digital has this analog version that only runs around $67. It has a 15K RPM limit, with a +/- 1 deg of accuracy. It can be treated like a potentiometer for all intents and purposes, but is actually an absolute shaft encoder.
Depending on what you are trying to do with it, this may also be an option.
Unread 04-10-2012, 18:36
That's a more reasonable example of an analog encoder.
I was actually thinking of its predecessor the MA2, but didn't know what the new model # was.
That model is quite tiny and great for compact spaces.
It's a less complicated interface dealing with it as if it were an infinite rotation potentiometer (without the drawback of a pot dead spot).
There are also interface circuits to be had that can turn a digital absolute encoder into an analog input.
Unread 04-10-2012, 19:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
This is a rather expensive but proven bulletproof product:
http://usdigital.com/products/encode...llow-bore/HB5M
We used it to monitor our shooter RPM. Installed very simply. Reliable, stress-free operation all season long.
