Go to Post Can you believe we have 8 FRC teams in Arkansas this year??? Not quite Michigan, but... - Meredith Novak [more]
Unread 04-10-2012, 18:21
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Kitbot interface
One of the tricks in our toolbox for prototyping is this product http://www.estoconnectors.com/index.php/connectors/thumbs/category/1-inch-square/. The connectors themselves are designed to fit into 1/16th of an inch 1 inch box extrusion. You can put a superstructure together pretty quickly and easily surface mount it to the KOP frame or the plywood bellypan as previously mentioned.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 04-10-2012, 20:49
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I know here at AndyMark we sell vertical attachments that bolt to the kit frame. You can use the vertical corner links to attach c-channel vertically and build up.
461 Westside Boiler Invasion
45 Technokats
Unread 04-10-2012, 22:57
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
We have used 1" 8020 extrusion. It's pretty fast to put together and it integrates pretty seamlessly with the kitbot. Just like the kitbot, it uses 1/4" hardware and regular 1" spacing.
It can be heavy and expensive, but if used properly it can save tons of time. (especially if you have limited machining resources)
Unread 04-10-2012, 23:45
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
if you are willing to modify your spacers, you can flip the inner rails, and use more of the corner extrusions to add inner structures. I'll have to try and find the CAD.
