Go to Post I'm definitely not advocating PVC tanks. I'm just saying that if you're going to be an idiot, please be slightly less of an idiot. - FourPenguins [more]
Unread 05-10-2012, 18:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Pressure tubes disconnecting
I have had bad connectors before. Cost us a #1 seed two years ago.
Also make sure your tubes are cut absolutely straight, it's best if you buy a tubing cutter.
One other thing the ends of tubes should be re-cut if you have taken them in and out a few times.
