Go to Post Life isn't a set track: you have to go out and make your own path. - Greg Marra [more]
Unread 04-01-2002, 22:40
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
well as far as getting the signal to the lcd projector a really long peice of coax cable would probally do it..
you may get a local radioshack, or other store like that to donate a roll and you give them the cable back after you use it, they should still be able to use it cause they cut it up anyway.
but you could run it into a vcr then out on some rca cables to the lcd projector. In this instance the vcr would handel the channel changing.
I would see if I couldent just use the middle school, prehaps a room in which they can patch the vidio into???
this is a lil late I know. but maby it will help.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Autonomous workking differently tethered in pits, than from feed during competition. Elgin Clock Programming 12 24-03-2003 17:00
NASA Feed on Charter Cable TV dhendrix General Forum 9 24-03-2003 09:12
Will the Web Broadcast be availbe to satellite archiver 1999 0 23-06-2002 22:38
Transponder info for live feed... archiver 2000 1 23-06-2002 22:14
Opinions of teh TV feed Wetzel Chit-Chat 4 29-04-2002 00:46
