Go to Post I will follow FIRST's guidelines, as long as they conform with those of the English language. - artdutra04 [more]
Unread 08-10-2012, 01:24
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
Re: How do I program a joystick deadband?
Allow me to show you a piece of code my team has used the last three years....
public double deadband(double JoystickValue, double DeadbandCutOff) {
if (JoystickValue<DeadbandCutOff&&JoystickValue>(Dead bandCutOff*(-1))) {
deadbandreturn=0;
else {
deadbandreturn=(JoystickValue-(Math.abs(JoystickValue)/JoystickValue*DeadbandCutOff))/(1-DeadbandCutOff);
return deadbandreturn;
this not only cuts it off at a point, but prevents jumping up to 0.1 after you get past it. it basically smooths the dead band curve. How ever, i would recommend making a algorithm you understand. ((i am still working on understanding this one. lol))
"you can build a perfect machine out of imperfect parts" -Urza
Unread 08-10-2012, 11:07
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
deadbandreturn=0;
else {
That's actually some pretty clever code... I'd like to put that on our robot this year, if you're okay with that.
To anyone confused:
The first if() checks if the joystick value is in the (-deadband,deadband) range (this could more succinctly be done with Math.abs(JoystickValue) < deadband), and if so, puts the output to 0. Otherwise, it scales the joystick value to [0,1] or [-1,0] depending on the sign by modifying the ranges this way:
[deadband,1] -> [0,1-deadband] -> [0,1]
[-1,-deadband] -> [-1+deadband,0] -> [-1,0]
deadbandreturn=(JoystickValue- // initially in one of two ranges: [DeadbandCutOff,1] or [-1,-DeadBandCutOff]
                (Math.abs(JoystickValue)/JoystickValue // 1 if JoystickValue > 0, -1 if JoystickValue < 0 (abs(x)/x); could use Math.signum(JoystickValue) instead
                 *DeadbandCutOff // multiply by the sign so that for >0, it comes out to - (DeadBandCutOff), and for <0 it comes to - (-DeadBandCutOff)
               ) // now in either [0,1-DeadBandCutOff] or [-1+DeadBandCutOff,0]
               /(1-DeadbandCutOff); // scale to [0,1] or [-1,0]
Unread 08-10-2012, 12:41
There's deadband in the motor controller too.
Unread 17-10-2012, 16:27
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
Personally, the best way I can think of to go about this would be to extend the Joystick class, making a DeadbandJoystick class. I'll write up an example of what I'm talking about when I get home tonight.
