Go to Post Stop whining about something that can be fixed by working harder. - artdutra04 [more]
Unread 10-08-2012, 04:13 PM
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Laser Pointer
Originally Posted by akoscielski3 View Post
It's still only a rule for Pre-Match, correct? Even if its mounted on the robot, or not mounted.
G02
Alignment devices such as templates, tape measures, laser pointers, etc. that are not part of the Robot and fully contained within the starting volume may not be used to assist with positioning the Robot.
Violation: Robot will be arbitrarily repositioned by a Referee prior to the start of the Match.
R08 D
Robot parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other Robots. Examples of items that will violate this rule include (but are not limited to): Exposed lasers other than Class I.
G02 prohibits the use lasers that are not part of the robot. Therefore the use of a laser must be part of the robot. R08 D prohibits any laser that is part of the robot that is not Class I.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-08-2012, 04:23 PM
Re: Laser Pointer
In other words, if you want to use a Class II (or III, or higher) laser for alignment, you can't. But, if you want to use a Class I laser mounted on the robot for alignment, at any point in the match, knock yourself out (though I do suggest making sure that the use of such a device doesn't violate any robot rules first--you never know when the GDC will slide in a rule about any robot with a laser must do a laser light show on the floor of the field or face a 50-point penalty ).
Yes, G02 is prematch only. But anything left on the field after prematch needs to be mounted on the robot...
Unread 10-08-2012, 08:45 PM
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Re: Laser Pointer
To make it easier to find, at what point in the video is that being shown? Is it just at the 2:10ish mark for the automodes?
At the very end the camera zooms in on the laser (it's on the top of that pole attached to the shooter). At ~2:13ish (the autonomous modes shots) if you watch the backboard reflective tape you can see the laser hit the reflective tape. That is the laser auto-aim function in action.
-Nick
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
