Go to Post And - I would never ever underestimate a rookie. Ever. - JaneYoung [more]
  #61   Spotlight this post!
Unread 10-09-2012, 12:06 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: FRC Blogged: - Motor Controllers
Something to think about.
-The Victor has been around for over a decade.
-It has never had internal over current protection and it has not affected it's performance on the field.
With the few failures I have seen most are caused from metal debris shorting the tabs of the H-bridge FET's. Although Internal over current protection would help prevent this, I think an even better approach would be to take measures to prevent the metal debris from entering in the first place.
Another thing to consider is the resistance of the power path feeding the motor controller. Al pointed out the role 10 gauge wire plays in this. Another even bigger player is the resistance of the Wago connectors, the 40 amp breakers, the PD and the internal resistance of the battery. In total you are looking at around ~40 mohms of resistance at 25 degrees C. This number increases significantly as these components heat up. If you have a way to measure internal resistance of your battery try performing the test at the power leads of the motor controller(with the controller out of circuit). You will be surprised at the amount of resistance that is actually present.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
