Go to Post Everyone who has posted on this thread has brought about a lot of different ideas to the plate. Before it was just a simple 1 course meal in my mind. But when you post something on CD with tons of engineers and engineers in the making, your bound to have a feast!! - gallo26 [more]
Unread 09-10-2012, 21:33
Zero_Viscosity Zero_Viscosity is offline
FRC #3344
Zero_Viscosity is an unknown quantity at this point
[FTC] Battery issue?
I began to test autonomous on a robot from last year. Unfortunately, I did not have the batter strapped down, it was just sitting on a bar. The robot stop abruptly and the battery fell off and a fuse blew. Is this normal behaviour? The robot was on a carpeted floor and is about 1.3 inches off of the ground.
Unread 10-10-2012, 01:15
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
Re: [FTC]: [FTC] Battery issue?
4 years of competition and robot abuse and we have never blown the fuse. Check for a loose connection and any shorts.
Jim Smith
FLL Coach
FTC Coach 3721
FRC Mentor 1983
Unread 10-10-2012, 08:33
Zero,
Anything is possible with a fall. It is likely that the shock caused internal components to punch through normal cell and/or wire insulation and short internally causing the fuse to blow or mechanically fail.
