| Track balls are red, Or they are blue - I get deflated, When I'm without you. |
Drivetrain Question
Hello all,
We have a cart in progress that we are going to make motorized. Our issue is that we want to be able to disengage the drive wheels from the motors to make it easy to push when not in use. We have yet to come up with an easy way to do this. So, CD, do you have a solution to our problem? Thanks, Ryan ![]() |
Re: Drivetrain Question
Consider running a shifter with a neutral gear.
How about this? Use motorized rubber wheels in contact with the cart's wheels to spin them. Mount the driving assembly in a way that can be pivoted or lifted to break the contact.
We have, but the problem the problem with the neutral space is that it's had to get working since they are not really meant to stay in neutral. Besides, four new shifters are not exactly in our budget.
![]() By the way, the drive wheels are mecanum. ![]() |
If this is a serious statement I would really reconsider. When moving around a mecanum wheels on anything but carpet at a quick pace you run into one of two issues
1) If it is slicker then carpet you get sliding and some minor issues with veering off to one side 2) Something rougher then carpet will damage the wheels quickly since they constantly are hitting it at an angle (also when you push around unpowered mecanums they make a lot of noise) |
#7
Drive wheels with v-belt; tension it to engage the drive, loosen to coast.
#8
This cart has gone through a season with non powered mecanums. They do make some noise, but they are not loud at all. If anything, they make people turn around and realize that there is a robot behind them.
Keep in mind this was tested on tile floors with decent grout gaps. And to Nate: This was our prior cart. http://www.chiefdelphi.com/forums/at...5&d=1333563144 http://www.chiefdelphi.com/forums/at...6&d=1333563152 V-belts are a good option. We don't know if the belts would slip under the stress though. |
#9
Evidently worked for them. |
#11
OP, consider disabling dynamic braking before you attempt a mechanical solution. That may be enough to comfortably push the cart around.
#12
Ever heard of a clutch?
#14
You could also get or mimic an OTS item like a wheelchair safety lock to prevent wheel rotation: ![]() |
#15
A couple of thoughts, If you are driving like typical robots, try using victor speed controls instead of Jags. Jags short the motor leads when off, so the motor is a brake. Victors do not do this, and you will not have this braking action when pushing.
Safety issue, put a electrical cut off switch by the controls. Fix it electrically, of course, I'm electrical. |
