Re: Drivetrain Question
Drive wheels with v-belt; tension it to engage the drive, loosen to coast.
Evidently worked for them. |
OP, consider disabling dynamic braking before you attempt a mechanical solution. That may be enough to comfortably push the cart around.
You could also get or mimic an OTS item like a wheelchair safety lock to prevent wheel rotation: ![]() |
#7
A couple of thoughts, If you are driving like typical robots, try using victor speed controls instead of Jags. Jags short the motor leads when off, so the motor is a brake. Victors do not do this, and you will not have this braking action when pushing.
Safety issue, put a electrical cut off switch by the controls. Fix it electrically, of course, I'm electrical. |
#8
#9
if the jag was in brake mode it would short the leads if it was in coast mode it would not.
#10
Disconnecting the motor from the wheels with the deadman switch will lead to the cart coasting to a stop, potentially over a long distance carrying a lot or momentum (150 lb robot + 50 or more lb cart...) - in other words, it can defeat the purpose and still run over a little kid. Instead of going that route, use some Jaguars to control the drive train. Set the Brake/Coast header to Brake, so when it stops, the motor actually helps the cart slow down faster. Hook all the limit switch inputs up to a limit switch sitting behind a slot. Slide a card into the slot will close the circuit, allowing the cart to move. If the card is pulled out, the circuit will open, and the Jaguars will immediately stop, with no programming needed on your part! This can separate your two issues nicely, which might let you use an easier solution for pushing the cart around than if the solution had to solve both problems at once. Oh, another idea I just had... a similar limit switch/slot concept, except the limit switch would activate some pneumatic cylinders, which would push some wooden skids straight down into the floor. Set it up so they can lift the cart wheels + robot completely off the floor. Now, the deadman switch serves two purposes - it stops the cart immediately, and while in your pit it can give you a more stable working surface that won't roll around! |
#12
A dead man's brake doesn't need to actually be part of the drive assembly.
One can arrest the momentum of a wheeled cart just by creating friction between the surface on which the cart rolls say by dropping a rubber covered shoe down on that surface to create drag (might want to tapper the edges on that shoe so it doesn't stop quite so violently that the robot might come off the cart). It might be much easier to make a brake like this. |
#13
I think your second idea could introduce a serious safety hazard. Pneumatic components that always return to one state when de-powered can actuate at un-intended times. If they are explicitly switched you might run into other issues. For example, the cart's battery could run low and the pistons could then actuate unexpectedly, causing the whole cart+robot to raise/lower without warning. If the skids default position were 'deployed' down, and there was an issue with the cart, it might come to stop in a hurry in a queue or pit lane, which would be most inconvenient. The idea of using skids to stabilize the cart for working is good, but I would not rely on them as a safety mechanism, nor would I have them pneumatically actuated. |
#14
The pneumatics wouldn't return to a specific state when de-powered, they would work the same as pneumatics on FRC robots - they remain in whatever state they were at when power was removed (air leakage might result in the pistons slowly losing their pressure). The switch simply indicates which direction they would be at. If you wanted to do this without needing a controller on board, see the attached rough diagram. |
#15
Of course none of this detracts from a pneumatic jack's usefulness and definite cool-factor FYI: plenty of FRC robots have one-way solenoid valves, i.e. return to one state when not powered. It would be dangerous to assume that all robots use 2-way solenoid valves. |
