Go to Post FIRST is nothing short of a community. - karinka13 [more]
Unread 10-10-2012, 19:45
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Drivetrain Question
Hello all,
We have a cart in progress that we are going to make motorized. Our issue is that we want to be able to disengage the drive wheels from the motors to make it easy to push when not in use. We have yet to come up with an easy way to do this.
So, CD, do you have a solution to our problem?
Thanks,
Ryan
We make easy things look difficult, everyday!
Unread 10-10-2012, 19:54
Chris is me's Avatar
AKA: Pinecone
Re: Drivetrain Question
Consider running a shifter with a neutral gear.
Unread 10-10-2012, 20:39
How about this? Use motorized rubber wheels in contact with the cart's wheels to spin them. Mount the driving assembly in a way that can be pivoted or lifted to break the contact.
Unread 10-10-2012, 20:47
1502's Avatar
AKA: Ryan G
We have, but the problem the problem with the neutral space is that it's had to get working since they are not really meant to stay in neutral. Besides, four new shifters are not exactly in our budget.
By the way, the drive wheels are mecanum.
Unread 10-10-2012, 20:54
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
If this is a serious statement I would really reconsider. When moving around a mecanum wheels on anything but carpet at a quick pace you run into one of two issues
1) If it is slicker then carpet you get sliding and some minor issues with veering off to one side
2) Something rougher then carpet will damage the wheels quickly since they constantly are hitting it at an angle
(also when you push around unpowered mecanums they make a lot of noise)
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 10-10-2012, 21:24
Nate Laverdure's Avatar
FRC #2363
Certain power wheelchairs (jpg link) have clutches built into the hubs to allow the wheels to spin freely if the chair is to be manually propelled.
Unread 10-10-2012, 21:32
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Drive wheels with v-belt; tension it to engage the drive, loosen to coast.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 10-10-2012, 21:45
1502's Avatar
AKA: Ryan G
This cart has gone through a season with non powered mecanums. They do make some noise, but they are not loud at all. If anything, they make people turn around and realize that there is a robot behind them. Keep in mind this was tested on tile floors with decent grout gaps.
And to Nate: This was our prior cart.
http://www.chiefdelphi.com/forums/at...5&d=1333563144
http://www.chiefdelphi.com/forums/at...6&d=1333563152
V-belts are a good option. We don't know if the belts would slip under the stress though.
Unread 10-10-2012, 21:50
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
This is the same way my lawn mower work's to spin the blades. Though it doesn't have a lot of torque needed so I can not say it would work or not. Prototyping is an option though
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 10-10-2012, 22:12
RogerR's Avatar
AKA: Roger Riquelme
The idea was shamelessly stolen from stuypulse's 2005 robot: http://www.chiefdelphi.com/media/photos/20224
Evidently worked for them.
Unread 11-10-2012, 08:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
OP, consider disabling dynamic braking before you attempt a mechanical solution. That may be enough to comfortably push the cart around.
Unread 11-10-2012, 09:34
1502's Avatar
AKA: Ryan G
The second goal of disconnecting the wheels for the motors is a matter of safety. Whatever way we end up doing it, there will be a deadman switch that works like one off of a treadmill. We like to keep our carts safe, and we're pretty well know for that.
Unread 11-10-2012, 20:24
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Ever heard of a clutch?
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 12-10-2012, 10:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
You could use the deadman switch to disconnect power to the motors directly, or through a relay, which would be similar to disconnecting them mechanically.
You could also get or mimic an OTS item like a wheelchair safety lock to prevent wheel rotation:
Unread 12-10-2012, 11:02
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
A couple of thoughts, If you are driving like typical robots, try using victor speed controls instead of Jags. Jags short the motor leads when off, so the motor is a brake. Victors do not do this, and you will not have this braking action when pushing.
Safety issue, put a electrical cut off switch by the controls.
Fix it electrically, of course, I'm electrical.
The sooner we get behind schedule, the more time we have to catch up.
