Go to Post last year's tradition is this year's rule change! - EricH [more]
Unread 10-10-2012, 17:45
mrjones2014's Avatar
mrjones2014 mrjones2014 is offline
FTC #0229 (Ampere)
mrjones2014 is an unknown quantity at this point
Question Is Teflon legal?
My team is building a scissor lift this year, and to help reduce friction, we were going to use Teflon bearings. This is my question: are we allowed to use Teflon in FTC? The manual says "Standard bearings and bushings", but what exactly does that mean? Are Teflon bearings considered "standard"?
Team #230 Ampere
Unread 10-10-2012, 20:50
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Re: Is Teflon legal?
They are referring to the standard bushings you get in the KOP.
We make easy things look difficult, everyday!
Unread 10-10-2012, 23:42
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Ask in the Q&A forum, they can give you an official answer
Unread 11-10-2012, 01:07
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Just wondering, why Teflon bearings? and not ball bearings which I assume are legal and would perform better.
Also this is an FTC question just for anyone that didn't catch that.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-10-2012, 09:04
Mrjones,
Under R02, d
d. The following additional structural parts, fasteners, and materials are allowed provided that they don’t violate other rules, such as safety, entanglement <R03>, etc. This includes no limits on quantity and size of the following materials:
2. Standard bearings and bushings.
I would interpret this as COTS devices listed as "bearings" or "bushings". The way you phrased your question, I am guessing you plan on using teflon bushings at the joints of the scissors lift. Under this rule I would expect them to be legal. The Q&A is the final answer however.
Ryan, the KOP bushings would be covered under R01 since they are "TETRIX, LEGO, and/or MATRIX" parts.
Unread 11-10-2012, 17:51
FTC #0229 (Ampere)
ummm, ball bearings would work, thats why.... ball bearings are more of a joint in themselves. Teflon bearings would just go between two pieces of metal.
Team #230 Ampere
Unread 14-10-2012, 23:45
PhantomPhyxer PhantomPhyxer is offline
FRC #2643
PhantomPhyxer is on a distinguished road
First you should ask this question. What is the advantage of using Teflon over either a oil impreginated bronze bushing or a standard ball bearing?
What is the load that is going to be applied to this joint?
Will the Teflon carry that load with a safety factor?
What are the material properties of the Teflon I am using.
http://www.ptfeparts.com/dupont/teflonlink8.htm
