Go to Post "Uh-oh, it's in crazy mode again. Hit the button!" - StephLee [more]
Unread 11-10-2012, 12:58
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: Need More Basketball Game Pieces
Originally Posted by squirrel View Post
In case you don't find any right away....after Lunacy, we needed some more "moon rocks" to demonstrate the robot, they were unobtanium. We discovered that $1 inflatable plastic balls available at Walmart worked great, when inflated to the correct pressure.
so, I suggest you go shopping
There are also some others online that look like they might be a close match although not quite as cheap. Do a search for Voit tuff coated foam basketball or Poof foam junior basketball. Both look similar to what we were using although I have no personal experience with either.
http://shop.ssgecom.com/esports(cz1T...sitemid_90 23[1]=3166XXXX&~okcode[1]=PRHRXS&~target[1]=
Possible better deal.
http://www.wolverinesports.com/categ...P&category&bc3
This is the zeroth day of the rest of your life.
