Go to Post Please don't confuse energetic enthusaism with acting obnoxious. - Alan Anderson [more]
Unread 14-01-2003, 17:50
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
In the Motion panel, under Assign Controller, your system has assigned a Path Constraint to the object's Position without a defined path, which is an error, so they don't move. All you need to do is change the Positionath Constraint back to Position XYZ.
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
