Go to Post [the last period is] a free for all, both goals are turned on, and any robot can go anywhere on the field and score in any goal (although I would recommend scoring in the correct goal, not your opponents :D ) - Ryan Foley [more]
Unread 11-10-2012, 23:31
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: WCD vs Standard
Originally Posted by LedLover96 View Post
So, doing more research on CD, I have come across bearing mounts called "Sliding Bearing Mounts". What are these exactly. It seems as if they are used for chain tightening, but I have no details about how they do this.
The idea is that the wheel, axles, sprocket, and bearings are all part of a block that slides back and forth along the chain path to adjust tension.
Here is a section view from our offseason project last fall. If you look carefully inside the tube, you can see the space the bearing block has to slide back towards the gearbox and loosen tension (to the right).
Also, here's a view of how we kept the bearing block in place. http://i.imgur.com/VrDEJ.png
It worked, but it really wasn't the greatest method. It should get you thinking though, and we came up with it halfway through building it.
