Go to Post Can't we also care about and celebrate the processes, the professionalism, the experience of healing? - Taylor [more]
Unread 12-10-2012, 00:18
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: WCD vs Standard
Originally Posted by compwiztobe View Post
Unfortunately, 254's website is under construction, so I can't pull up any of the great pics I know they had there. I'm sure someone else here can dig up some instructive photos.
I can't find a good picture of the bearing blocks themselves, but here's a shot of the rectangular holes in the frame where they go. You might get a better idea from browsing the rest of the 2012 build season album. Basically, there are two halves that come in from either side of the rail and fit inside each other, each having a bearing pressed into it. Long bolts through the rail are used to hold the two halves together, and there's a cam mounted to the rail that is torqued once the chain is installed to push the block which tensions the chain.
Originally Posted by BJC View Post
It's interesting to hear so many people say that canilevered, direct driven systems are the lightest and best when some of the most successful teams in the world do neither of those things (most notably 67 and 1114).
I wouldn't say that weight is the top factor in 254's choice of using a cantilevered drive year after year. It probably only comes in fourth after ease of maintenance, robustness, and aesthetics (you wouldn't believe how many design decisions come down to aesthetics).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 12-10-2012, 11:49
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: WCD vs Standard
I can't say for sure, but my notes say that I weighed our competition chassis (0.06" sheet AL) at 8lbs, before we started assembling any of the components on to it.
Weight is a factor in our decision to use this type of drivetrain...but, it's probably #3 on the list. #1 would be resources available (in-shop waterjet) and ease of construction (no welding) and #2 would be robustness.
Our design is a nightmare for ease of maintenance. Changing wheels or drivetrain components is not something we could do easily/quickly.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 12-10-2012, 12:20
Chris is me's Avatar
AKA: Pinecone
Re: WCD vs Standard
I think the main reason anyone does any type of drivetrain the way they do is because they have access to resources that make their design optimal. A sheet metal chassis can be done excellently. So can a welded tube chassis. Rather than sketch an exact copy of the best, drive design should play to the resources your team has. What use is a drive that's 5 pounds lighter of it takes you 2 weeks longer to build it?
We use a Poof inspired but *highly* derivative drivetrain that plays into our resources and goes together relatively quickly. It's light enough. It's definitely strong enough. Probably overbuilt. And it works because it uses what we have and what we were able to get in an offseason.
The way the Poofs do it, when you get down to the details of their bearing blocks, custom wheels, etc. takes a lot of resources that not a lot of teams have as readily available as 254 has worked hard to have. Play to your strengths.
Unread 12-10-2012, 16:10
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: WCD vs Standard
That makes sense, most of my parts will probably be bought from andymark. But I would still like to know how many teams mount these bearing blocks, and allow them to slide, then lock them into place when they are done with them. Thanks!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 12-10-2012, 18:09
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: WCD vs Standard
Pat's post explains how we do it. The combination of his post, the picture of our frame rail he linked, and Gray Adam's cross section view of their 3d model should be a perfect explanation of how it works.
2001-2004: Team 100
2006-Present: Team 254
