Re: pic: How do you fix this?
As long as this doesn't clearly affect the scoring of subsequent game pieces, I would think it should be treated like a ball "stuck" under the bridge during a match.
If you really needed to fix it, could pokey-stick guy use the 3 in.-ish looking hole in the diamond plating to dislodge the ball? Looks like it's the lowest goal since the fender is so close and there is diamond plating so I don't know if there would be enough ground clearance for that. Then again, I would guess most teams would be rolling balls into the lowest goal or not going for it at all, so I doubt this would impact the outcome of a match.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
