Go to Post Remember everyone, during build season, if you mess something up..... In the words of Adam Savage... Failure is always an option! (and so is blowing stuff up) - J.Warsoff [more]
Unread 14-01-2003, 18:23
DaveG702's Avatar
DaveG702 DaveG702 is offline
#0702 (Bagel Bytes)
DaveG702 is an unknown quantity at this point
Question Optical Sensor Return
Can anyone tell me what the optical sensor returns to the RC in terms of a number (i.e. if the optical sensor sees white, what will it tell the brain?)
Unread 14-01-2003, 18:26
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 14-01-2003, 19:09
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Ergh.
Read my sig.
There're two digital outputs (either 1 or 0) on the Banner Optical Sensor. When the sensor sees its reflection, one is high (on) and the other is low (off), and when the sensor is not seeing the reflection, the opposite is true, the one which was low is high, and the one which was high is low.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 15-01-2003, 13:38
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Have it your way! (no supersizing though) :mad:
Originally posted by Jeremy_Mc
*jeremy
or Zero....your choice!
Live free or die....
Unread 15-01-2003, 16:55
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
It depends which wire you use for the digital input (black or white).
Posted by Jnadke (last year):
Hook the brown to + (12V circuit breaker), blue to - (ground).
Don't tie black and white together.
When nothing is sensed, the circuit for the black is closed (1) and the white is open (0). When the light is reflected and sensed, the black is open (0) and the white is closed (1).
Just hook both white and black to SEPARATE digital inputs and debug the variables. You can find out by trial and error. When you figure it out, you only really need 1 wire to detect 1 or 0.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 15-01-2003, 19:34
crazycliffy crazycliffy is offline
crazycliffy is an unknown quantity at this point
If we supply 12V power to the sensor, then
What happens if we plug the sensor outputs to
the robot controller's (RC) digital input?
Couldn't the amount of current, and voltage
going to the digital input blow up the circuits
in the RC? I though we could only supply
voltages in the range of zero to five volts.
Unread 15-01-2003, 19:44
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
When the optical sensor "sees" something, it will connect the sensor wire to ground, not to +12V. You are correct to be careful about how much voltage you are pumping through the RC, but in this case you are safe. Likewise, when you wire up limit switches, etc, always connect them between ground (from the RC switch port) and the switch pin.
Unread 15-01-2003, 22:45
Go Badgers!
#0093
The 12V power source is for powering the light source on the optical sensor. None of it gets sent to the robot controller.
The robot input is actually a positive lead that supplies 5V @ a maximum of 10mA. This is far too little to power the sensor.
optical sensors majormusic2005 Electrical 5 11-03-2003 21:32
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
