Go to Post The solution to that "problem" is obvious: practice driving. - Alan Anderson [more]
Unread 09-10-2012, 12:46
kbocheltree kbocheltree is offline
FRC #4122
kbocheltree is an unknown quantity at this point
Unable to deploy over Ethernet using WindRiver C++
This is our second year and we are moving to C++. We are able to build our projects using WindRiver and have only been able to deploy them over wireless, ethernet will not allow use to deploy the code, it hangs on transferring the code and never starts. We can do everything using wireless, but as soon as we try using wired Ethernet, it won't deploy
In Ethernet (With wireless disabled)
1. We are using the static IP address
2. We can ping the cRIO over ethernet
3. We can see the communications to the remote cRIO in the WindRiver window
4. Firewall and Antivirus was turned off
Any other suggestions? Is there a good way to get a trace to see where it fails?
Unread 09-10-2012, 13:17
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Unable to deploy over Ethernet using WindRiver C++
Make sure the FIRST Downloader settings are set correctly. I think they're under Window -> Settings.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 13-10-2012, 12:43
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Different team, same issue. The Getting Started with the Control System page says the file we should download is C:\WindRiver\workspace\DefaultRobot\PPC603gnu\Defa ultRobot\Debug\DefaultRobot.out but that doesn't exist for us. What file should we be downloading?
Unread 06-01-2013, 19:24
mprasolov's Avatar
mprasolov mprasolov is offline
Jack of all trades
AKA: Misha Prasolov
FRC #2823 (The Automatons)
Team Role: Student
mprasolov is an unknown quantity at this point
We experienced a problem exactly like that. My laptop is capable of compiling and downloading programs, but another programmer's laptop just would not do it, even with the same IP settings, WRWB settings, and code. Try on another computer and see if that helps!
Unread 06-01-2013, 19:42
Replace instances of DefaultRobot with whatever you called your project.
Unread 06-01-2013, 21:28
AKA: Brad
#0190 ( Gompei and the Herd)
Just clarified the directions to show how to find the .OUT file you need to use in the FIRST Downloader preferences. Look at the last few sections at the bottom of this web page:
http://Wpilib.screenstepslive.com/s/3120/m/7913/l/79735
Brad
Brad Miller
Robotics Resource Center
Unread 08-01-2013, 00:45
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I'm a bit surprised to hear this inability to deploy and yet you can ping the cRio -- have you tried ftp'ing with the cRio just as another way to poke at the beast? On the computer that DOES transfer (or in the mode in which it transfers - wireless) -- goto a browser and type into the address bar
ftp://10.xx.yy.2
where xxyy is your team number (for our team 1967 it is ftp://10.19.67.2)
If you can see files/directories, then you've successfully made an ftp connection to the cRio. Then switch to the other non-transfer-able computer (or switch off wireless and go to wired mode) - re-do the same test. Whether you are able to ftp or not might help illuminate the issue here. Brad might be able to help a bit more based on these results.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 08-01-2013, 01:32
Fifthparallel Fifthparallel is offline
AKA: Sam Chen
FRC #1410
Fifthparallel is an unknown quantity at this point
I had a similar problem when the Driver Station had changed my subnet on my wireless connection to 255.255.255.0, and I had 255.0.0.0 as the subnet for my ethernet connection (cRio was in the 255.255.255.0 subnet).
It was 2 years ago, though, and I don't rightfully remember if that was the same problem.
sudo chmod u+x helloworld.sh
gotta start somewhere.
