Go to Post I'll do my best, but I'm this --><-- close to telling our drivers they're NASCAR styling it this season..."Sorry boys and girls, left turns only!" - Mr. Lim [more]
Unread 13-10-2012, 22:54
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
WPILIBJ java.io.File equivalent
What class in the WPILIBJ would provide similar functionality as the java.io.File class does in Java SE? I can't seem to find anything appropriate.
Also, how would I be able to read a .TXT file via ftp to the robot? Ideally I'd like to have a method that converts the contents of the file to a string. I have done this in SE with Scanner in Java SE, how would I do it with FileInputStream or something of the like?
Example of what I'd like to do in Java SE :
public static String getStringFromFile(File file) throws FileNotFoundException {
    if (!file.exists()) {
        throw new FileNotFoundException();
    try {
        return new Scanner(file).useDelimiter("\\A").next().trim();
    } catch (java.util.NoSuchElementException e) {
        return "";
All opinions are my own.
Unread 14-10-2012, 23:30
krieck's Avatar
krieck krieck is online now
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Re: WPILIBJ java.io.File equivalent
You can read and write files on the cRIO using the com.sun.squawk.microedition.io.FileConnection class. FileConnections are opened using the javax.microedition.io.Connector class.
And yes, you should be able to read and write text files through FTP.
Unread 15-10-2012, 15:12
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Take a look at these threads for some pointers:
http://www.chiefdelphi.com/forums/sh...217#post924217
http://www.chiefdelphi.com/forums/sh...440#post949440
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
