Go to Post In Israel we've got the president supporting FIRST and speaking at events, so it's time for you guys to catch up =] - Tottanka [more]
Unread 08-10-2012, 18:58
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
AndyMark CIMple Box Stripped Out
So earlier today we were demoing our robot when it started making a nasty grind, and suddenly our CIMple box on our right side drivetrain locked up. This seems totally bizarre seeing as how both the CIM gear and the output gear are made of steel. Has anyone ever had a problem like this with a CIMple box? We're a little unsure whether it's going to wind up being a stripped cim or output gear, which basically will determine what we need to disassemble and replace. Has anyone had any similar experiences?
Unread 08-10-2012, 19:04
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: AndyMark CIMple Box Stripped Out
Obvious (?) question...was the gearbox properly lubricated?
"A genius is just a talented person who does his homework" T. Edison
Unread 08-10-2012, 19:10
AKA: Bobby Van Ness
When it was installed during build season, I'm fairly sure we did lubricate it.
Unread 08-10-2012, 19:12
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
They do need periodic lubrication....
Other possible problems are loose screws, or the key falling out
Unread 08-10-2012, 19:24
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
The sudden failure described suggests that squirrel is on the right track there.
Did you disassemble and inspect yet, and if so what did you find?
Richard Wallace
since 2003
Unread 08-10-2012, 19:40
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
If it locked up, it's unlikely that the teeth are stripped away.
--Madison--
...down at the Ozdust!
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
If you stripped a gearset you would be having the exact opposite of the problem you described. If it's locked up it's probably because a set screw or keyway has come loose inside the gearbox, as mentioned before.
Have you disassembled the gearbox yet? You'll get much more information from the gearbox itself than you will from a bunch of CD'ers trying diagnose your problem based off of one symptom.
Edit: In hindsight it was probably the external self-locking retaining ring popping off the CIM shaft and getting jammed between the gears. But if there was a grinding sound beforehand then you might have larger problems.
Unread 08-10-2012, 19:43
AKA: Bobby Van Ness
We havent disassembled it yet, we've scheduled to fix it later this week back at the school. I'll post what it was once we confirm the problem.
Unread 08-10-2012, 20:09
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
So your gearbox failed, and your first course of action was to post about it CD?
This is an interesting failure recovery plan.
Opening it up is probably a good next step.
-John
Unread 08-10-2012, 20:34
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
We had this same thing happen to us just after the fall classic in 2011 with our back left drive gear box. Ended up that the teeth on the large gear had worn away and one of them had failed. Pretty sure the issue was the we didn't grease it enough during the season and we drove that robot pretty hard.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 11-10-2012, 22:19
AKA: Bobby Van Ness
For anyone still interested, the cause of the drivetrain malfunction was two completely stripped 12 tooth CIM motor gears. According to our lead pit mentor, we oiled it routinely throughout competition, but we must have let it slip this summer. Proper lubrication is certainly important to avoid things like this happening, we're just lucky it happened at the end of a demo, not at an offseason competition.
Unread 12-10-2012, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Oiled or greased?
Unread 12-10-2012, 01:47
I think many of us would like an explanation as to how exactly a stripped gear made your gearbox lock up.
Unread 12-10-2012, 18:42
AKA: Bobby Van Ness
Originally Posted by sanddrag View Post
Oiled or greased?
I'm not entirely sure, I wasn't in charge of that.
Unread 15-10-2012, 00:08
PhantomPhyxer PhantomPhyxer is offline
FRC #2643
PhantomPhyxer is on a distinguished road
Is oli the right lubricant? I would suggest a gear grease developed for high gear pressure.
