Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
Unread 09-10-2012, 22:35
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
Raspberry Pi as robot controller
I wonder how well this would work, the raspberry pi does have the processing power to do this, and the gpio could do the interfacing.
This is just an idea, up for discussion, What do you think?
Unread 10-10-2012, 01:28
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Raspberry Pi as robot controller
Well when I get mine, I'm planning on having it talk to an arduino (which may or may not talk to another arduino) and do some localization/vision processing/dead reckoning/video feedback.
I don't think the foundation technically supports any RTOSs for the pi, and I'd be weary controlling a robot during the time when the cron jobs start running (or whatever)
Unread 10-10-2012, 10:44
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Linux is perfectly capable as an RTOS. A system patched with RT_PREEMPT (which has ARM support) would have more than sufficient realtime for our purposes.
Just wanted to clear that up.
Unread 10-10-2012, 14:48
FRC #0228 (Gus)
Yea especcialy with the gpio pins it could have a lot of potential in the robotics community
Unread 11-10-2012, 02:03
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
The Pi itself is pretty lame as a robot controller. The GPIO pins are all 3.3V, and there isn't any analog IO. That's not to say you couldn't build a cool shield/cape/extension board that would give you a lot of robot control functionality, and people are working on it.
The idea of having my robot be a full-blown Linux box is pretty appealing. I think I'd take the new Vex ARM9 controller (which also runs Linux) over the Raspberry Pi when it comes to robot functionality, but it's hard to beat $35.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 15-10-2012, 13:52
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Lots of people in the Raspberry Pi forums are working on this. I bought three Pi's to play with, and am progressing a little at a time, adding functionality necessary to make a Pi a viable robot controller. (I'm a mechanical engineer, not a software guy.) I hate to advertize my future plans, because the web is full of people announcing big plans with no follow through. But, to date I have been successful in using the Raspberry Pi to control a Jaguar and a servo using a joystick as an input device. With no additional hardware, you can control up to 8 PWM channels. Adafruit sells a $15 accessory board from that lets you add 16 PWM channels at a pop. And it's only a matter of time before other inexpensive boards hit the market allowing for analog and digital I/O.
Video of joystick control here: http://www.youtube.com/watch?v=0ODQY2mDYR0
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 15-10-2012, 14:16
How are you generating the PWM signal to the Jag and servo? Is it one of the following, or something else?
- does the Pi have built-in hardware support for generating PWM signals on the GPIO pins so all you have to do is configure the period for each channel and then provide a pulse width for each channel?
or
- continuously poll a clock and turn GPIO on/off for each of the two PWM channels as appropriate based on the respective joystick inputs
or
- use a fixed-period interrupt with a counter and a state machine to turn GPIO on/off to turn the GPIO on/off
or
- use a fixed-period interrupt (at the desired period of the PWM) which turns the GPIO on and then enables a one-shot interrupt to turn the GPIO off
or something else?
