Go to Post In fact, our robot YOLOs so hard it does drive-bys on the refs. - TrevorKN [more]
Unread 15-10-2012, 22:08
Anorak Anorak is offline
FRC #2550
Anorak is an unknown quantity at this point
Fisher Price Motor Variable Speed Moderation
How does one change the speed on the variable speed Fisher Price Motors included in the KOP?
Unread 15-10-2012, 22:51
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Fisher Price Motor Variable Speed Moderation
Are we looking for a method to do so without a motor controller? Generally the speed is changed via programming and some sort of manipulator, usually a joy stick.
Academic Student (Forever)
Unread 16-10-2012, 09:16
FRC #2550
No. We have a Victor on it, but we want to be able to change the speed in the programming. Is there like an open-source Fisher Price puts out for these motors?
(These are the motors you see on those toy-car things you see kids driving around these days...)
Unread 16-10-2012, 20:39
What are you using as a control system? Is it something fancy like a cRIO? Something simpler like a VEX Cortex? Something even simpler like an Arduino? Something super-simple like a PIC? How are you programming it?
Unread 16-10-2012, 23:19
FRC #2550
No, we have a cRIO to control it, and are programming it in C++
Unread 17-10-2012, 10:45
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Are you using the correct variable types in your code? It sounds like you are using an int or char, which would only allow you to use three speeds.
You should be using a float, which can contain nearly any* decimal value. The speed controller classes, such as Victor, require a value between -1.0 and 1.0. To run at any speed other than full, simply send values like -0.62 or 0.48 or 0.11 or -0.88.
* Within a reasonable magnitude. See this for more info: http://en.wikipedia.org/wiki/Floating_point
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-10-2012, 12:33
You know...
In terms of coding, FPs aren't all that different from CIMs if they're controlled by a Victor (or, for that matter, a Jaguar). I'm willing to bet that you've got some variable-speed CIM code somewhere around (probably in the drive code). Take a look at that and see if you can't figure out how to copy and adjust it to get the FP working.
Unread 17-10-2012, 12:46
You're using C++, a cRIO, a Victor, and a Fisher-Price motor. You want to control the speed of the motor using software? What you're asking is such a basic part of programming an FRC robot that I have to wonder if I don't understand the question.
Pretend that the software is already done and working, and describe how you want to control the speed. Try to be as specific as you can, like "pulling back a little on a joystick will make the motor run slowly forward, pushing forward a lot will make the motor run quickly backward," that sort of thing. That'll help explain more clearly what you want the software to do.
