Go to Post .. just don't try to sell/trade your freshmen or something silly like that. :) - Brandon Martus [more]
  #46   Spotlight this post!
Unread 15-10-2012, 23:57
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: CalGames 2012: Info
As an alumni, it's always great going back to CalGames, helping out my team, and enjoying the competition. As always, Woodside put on a great event, and a huge thank you to them.
On a side note, would anyone from 254 mind clarifying what happened during F1? From what we were told, a CIM was blown, but I'd be really interested in knowing the circumstances around this.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
  #47   Spotlight this post!
Unread 16-10-2012, 12:59
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
From what I saw on the field, 254 lost the tread on one of their wheels and had to replace it. Im fairly sure no one on the winning alliance burned out a motor durring the finals. Correct me if I'm wrong.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
  #48   Spotlight this post!
Unread 16-10-2012, 18:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Are you referring to the smoking smell? I believe that was a piece of material on 1678's intake roller that was rubbing elsewhere on their robot, causing it to burn/smell.
254's robot had a disconnected pneumatic tube which caused some pneumatic components to only partially work. It was reconnected between matches and was fine for F2.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
  #49   Spotlight this post!
Unread 16-10-2012, 18:17
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Any smoke smell in the finials came from us, like you said. There were some problems in our intake system causing excessive friction leading to two of our 550's getting quite hot and smoky, but not fully blown.
  #50   Spotlight this post!
Unread 16-10-2012, 21:23
hionwind's Avatar
hionwind hionwind is offline
Lead Mentor
AKA: Steve Harvey
hionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant futurehionwind has a brilliant future
Actually, the burning smell was coming from the motor(s) for our "sweeper" that carries the balls from the intake area up to the shooter wheel. The roller had jammed causing the motors to overheat. That is why we were unable to shoot in the first final match and why we called the time out. We un-jammed the roller and did a systems check which showed the motors to be running but, unfortunately, in the second final match the problem recurred and we were unable to shoot again.
Lead Mentor - Team 1678 (2005-Present)
2013 Curie Division Champions (with 148 and 862)
2014 Newton Division Champions (with 1114, 1640 and 5136)
2015 World Champions (with 118, 1671 and 5012)
2016 Hopper Division Champions (with 148, 364 and 2990)
  #51   Spotlight this post!
Unread 17-10-2012, 00:42
rahilm's Avatar
AKA: Rahil Mehta
Thanks for clearing that up. There must have been some miscommunication/misunderstanding. This makes much more sense than the impression I was under.
  #52   Spotlight this post!
Unread 18-10-2012, 14:36
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Check out some pictures that Craig Zarmer took at CalGames 2012
http://www.zarmer2.com/pix/CalGames%202012/index.php
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
