Re: Side of Drives Giving Out
If this really is the issue, I'm going to try and make a second push to make the necessary mechanical upgrades. |
If your team is hesitant about replacing both CIMs, you should be able to stick some FPs through AM Planetaries for a bit of a boost in your drive. A bit pricey if you don't have the parts lying around though.
Other factors to consider with this: Where is your CG? If it's too high or off to one side this problem might present itself, but you'd probably notice the robot being quite tippy already. |
FRC motor controllers can easily deliver current well above 40 amps, which in short bursts wont trip the pdb breaker immediately, but if your cims are sitting stalled on the bridge, it is likely that this is your problem. This could be due to the gearing ratio also, and the motors not having enough torque to keep driving up the bridge. Maybe consider a change in your gearing ratio.
CIMs don't have internal breakers, so they will keep going until they are dead. Once dead, they are DEAD. They can be worn from hard use and simply swaping in a fresh pair might help, but not likely.
It sounds like you are either tripping the breaker, or resetting a Jag. You didn't mention which speed controllers you were using, but by the sound of it, I'm guessing they are Jags. Either way, you are over currenting your drive. Check for binding in your drive train. Check for chain misalignment. Lubricate your transmissions and chains. Possibly, change your output sprocket to a smaller one to gain more torque out of the transmission. If all else fails, swap the Jags for Victors. |
I fully agree with Chris. To check whether that's the reason, check if the CIMs heat-up more than they usually do. If they don't heat up, it won't say much for or against the theory (because from what I understand the situation only lasts a few seconds), but If they do, overload is almost definitely your problem. I want to say definitely, but I've seen enough strange things to not commit to it
![]() Also, if the CG is a bit closer to the left (and the overload theory is correct), it might explain why the left gives out more often than the right. A related long-shot: do you have a turret? |
If you are using Jags/PWN switch the jags and see if the stall is opposite. Could be you are resetting your Jags dues to improper gearing and stalling the CIM. Makes sure your firmware on your jags are up to date.
If you can switch to Victors try that. Last edited by roystur44 : 16-10-2012 at 18:07. |
#7
Leeland, I also agree with chris that you probably don't have the torque. If you don't want to run the ruckus with 6 CIMS, I would suggest you swap out the CIMple box with the tougbox from the previous years. There is a larger reduction in that gearbox for more torque and shouldn't be too hard to make this change.
It would also help if you know what the reduction is after the cimple box. |
#8
It sure sounds like an overload tripping the breakers.
Also check the gear ratio in the gear boxes. If you have the 4?? to 1 it would cause the problem you are having. |
#9
Was the robot ever able to climb the ramp? If this is new then look for something wrong. Cims are very reliable, but they can be burned at by extended use at high loads. (Which is beyond their design spec)
Otherwise it sounds like you do not have enough torque. If adding motors in not an option, you can lower the drive ratio by changing the chain sprockets on the wheels. You will lose speed but gain acceleration, turning & pushing ability along with climbing ability. Sprockets are available from AndyMark. Our locomotion chassis is geared for about 10 ft/s & has no problem climbing the bridge. (long chassis, 6 wheel drive, Simple boxes, 8 in wheels, 1 cim per side.) |
#10
I appreciate the advice everyone has given so far.
My first course of action is going to be to try and rally the mechanical mentors on the team and make the motor changes we had planned on earlier, including moving 2 CIMs to the drive base. If that doesn't work or I can't get enough support, we will try changing the sprockets on the wheel to larger ones to lower the ratio. Since that seems like a substantially less time consuming job, this seems like a likely route if I can't find the support to change the motors. Again, thank you everyone for all the help. I will be doing more research Thursday, as well as talking with mentors about getting things in gear for upgrades. Quote:
#11
are you running jags? you might be popping the over current protection when you climb the ramp.
#12
We are indeed using jaguars on our robot.
#13
I would never advocate doing this in-season, however it's an offseason, why not just run the 6 CIMS? A number of teams did this in the offseason after the whole BB775 case short issues. I'd just contact the Ruckus planning people to double check.
I'll even come over and help you out in the morning when I get there if you need it. |
#14
Leeland,
The Jags have an over current protection circuit that will remove motor drive for 3-4 seconds and flash the red LED on the face of the Jag. When a breaker trips open it resets almost immediately and there is a audible click. When repeatedly tripped it can cause a buzzing sound. It is quite possible that over the months since build, hardware has loosened and mechanical parts have moved. This could cause friction in the drive that was not present earlier in the season. Since you state that the robot can drive after a few seconds, my money is on the Jag over current protection. Note: We had some CIM failures earlier this season. Upon inspecting the interior of the motors, we found that some of the winding wires had actually broken away from the commutator. These were older CIMs and had been put through some excessive driving. I believe that the overheated motors weakened the copper at stress points and caused the cracks. I posted pictures in a different thread earlier this year. Last edited by Al Skierkiewicz : 17-10-2012 at 09:36. |
#15
I did notice a Jaguar flashing red when we lost driving ability, but I'm not sure if it was the Jaguar responsible for the drive motors. I'll check that Thursday. When testing, I'll also have someone watching the Jaguar for the right drive motor, to see what happens when that side fails. I will also see if we can pull together and get an effort to perform maintenance on the mechanical parts to help adjust the friction in the drives. Also, thank you very much, Justin and Nick! I really appreciate the offer. Our goal right now is to be able to show up to Ruckus and not need extensive repairs, so that's what we're working towards. I really do appreciate the offer, and I will let you know if we will need to take you up on it ![]() |
