Go to Post It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches. - Joe Ross [more]
Unread 16-10-2012, 17:14
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: Side of Drives Giving Out
I fully agree with Chris. To check whether that's the reason, check if the CIMs heat-up more than they usually do. If they don't heat up, it won't say much for or against the theory (because from what I understand the situation only lasts a few seconds), but If they do, overload is almost definitely your problem. I want to say definitely, but I've seen enough strange things to not commit to it
Also, if the CG is a bit closer to the left (and the overload theory is correct), it might explain why the left gives out more often than the right.
A related long-shot: do you have a turret?
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
