Originally Posted by Travis Covington
Are you referring to the smoking smell? I believe that was a piece of material on 1678's intake roller that was rubbing elsewhere on their robot, causing it to burn/smell.
254's robot had a disconnected pneumatic tube which caused some pneumatic components to only partially work. It was reconnected between matches and was fine for F2.
Originally Posted by hionwind
Actually, the burning smell was coming from the motor(s) for our "sweeper" that carries the balls from the intake area up to the shooter wheel. The roller had jammed causing the motors to overheat. That is why we were unable to shoot in the first final match and why we called the time out. We un-jammed the roller and did a systems check which showed the motors to be running but, unfortunately, in the second final match the problem recurred and we were unable to shoot again.
Thanks for clearing that up. There must have been some miscommunication/misunderstanding. This makes much more sense than the impression I was under.
