Go to Post I'd like to thank FIRST for giving me this wonderful opportunity. I've learned so much! - Leav [more]
Unread 17-10-2012, 10:45
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Fisher Price Motor Variable Speed Moderation
Originally Posted by Anorak View Post
No, we have a cRIO to control it, and are programming it in C++
Are you using the correct variable types in your code? It sounds like you are using an int or char, which would only allow you to use three speeds.
You should be using a float, which can contain nearly any* decimal value. The speed controller classes, such as Victor, require a value between -1.0 and 1.0. To run at any speed other than full, simply send values like -0.62 or 0.48 or 0.11 or -0.88.
* Within a reasonable magnitude. See this for more info: http://en.wikipedia.org/wiki/Floating_point
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-10-2012, 12:33
You know...
In terms of coding, FPs aren't all that different from CIMs if they're controlled by a Victor (or, for that matter, a Jaguar). I'm willing to bet that you've got some variable-speed CIM code somewhere around (probably in the drive code). Take a look at that and see if you can't figure out how to copy and adjust it to get the FP working.
Unread 17-10-2012, 12:46
You're using C++, a cRIO, a Victor, and a Fisher-Price motor. You want to control the speed of the motor using software? What you're asking is such a basic part of programming an FRC robot that I have to wonder if I don't understand the question.
Pretend that the software is already done and working, and describe how you want to control the speed. Try to be as specific as you can, like "pulling back a little on a joystick will make the motor run slowly forward, pushing forward a lot will make the motor run quickly backward," that sort of thing. That'll help explain more clearly what you want the software to do.
