Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 17-10-2012, 09:43
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Robotics Question of the Day!
Hi, All
We're looking for questions related to robotics that would start our meeting off. They can be related to pretty much anything as long as the average kid can answer with a bit of thought. We'd like a fun way to get the kids' minds going and would like to try it out. Also, if your team is doing this, how is it going? Feel free to use this idea if you'd like.
My example was, "How can decreasing a drivetrain's gear ratio increase its top speed?"
Post your questions below.
Thanks,
Ryan
We make easy things look difficult, everyday!
Unread 17-10-2012, 11:25
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: Robotics Question of the Day!
Here are a few.
1. If FIRST changed the rules and allowed you the option of a second battery, would it be an advantage to use it, a disadvantage, or does it depend on the game, your strategy, etc. and how?
2. Each year there are robots with different drive mechanisms, but only a few types seem to be represented as a significant percentage in the finals. What is it that makes some of the different drive trains more or less competitive?
3. When building a robot you can choose different materials for the frame and other key parts such as aluminum or steel tubing, strut, sheet metal, wood, plastic, etc. How do the properties of these materials affect the choice and how many properties are there that are important in a decision on what to use?
4. Many teams are building T-shirt launchers to help promote their teams. If you wanted to build one, what design factors would you need to consider if you wanted to shoot T-shirts into high bleachers.
This is the zeroth day of the rest of your life.
Unread 17-10-2012, 17:15
sg999 sg999 is offline
Programming Lead, Co-Captain 2013
AKA: Bella
FRC #0999 (Mecharams)
sg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to beholdsg999 is a splendid one to behold
Here's one I used for discussion in an FLL team I mentor:
What would I have to do to a two wheeled vehicle to make it stable? (Make them think outside the box- I got some really interesting responses, some of which were practical and helpful)
There is always time-whether or not you use it productively is up to you.
2012-WIWI 6th seed (Thanks for being awesome alliance partners, 1991 and 178)
2014-present College student at Caltech (math/CS)
Unread 17-10-2012, 21:29
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
How can increasing a drivetrain's gear ratio increase its top speed?
FRC 766, 2015-, Mentor
Unread 17-10-2012, 21:36
Nate Laverdure's Avatar
FRC #2363
Confusing to talk about increasing a ratio (e.g. 10:1) because it's unclear which quantity (1 or 10) you're increasing. Better to ask "How can decreasing a drivetrain's gear reduction increase its top speed?"
Unread 17-10-2012, 21:41
1502's Avatar
AKA: Ryan G
When the gear ratio is too big for the wheel and motor combination. We experienced it this year. We put on a sprocket that was to small by accident and it would barely move. We doubled the diameter of the sprocket on the wheel and we were golden.
Thanks for the replies, and keep them coming!
Unread 17-10-2012, 22:46
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
How about:
What is the most important part of the robot?
A.The drivetrain
What is the second most important part of the robot?
A. Game piece pick-up
Have to keep these in mind come design time, its easy to only think about scoring..
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 17-10-2012, 23:07
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
If you are 100% sure you can score 2pts in the end game, but have the possibility (~50%-65% chance) of scoring 3pts if you skip the end game, which should you choose?
This was something that we had to ask ourselves back in 2010 nearing the end of season on debating whether to add the hanging mechanism.
Academic Student (Forever)
Unread 18-10-2012, 00:23
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Depends on whether the extra point is needed to win.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 18-10-2012, 00:51
CalTran's Avatar
MST Rolla Senior
Also bear in mind, for discussion on cd, that 2010 was year of the horror ranking system. But for purposes of the op's post we can throw that out the window since rookies are highly unlikely to understand (I sure didn't) the system.
Unread 18-10-2012, 01:24
RyanCahoon's Avatar
I guess I think about it as increasing or decreasing the equivalent fraction (10/1 in the case of your example). Maybe I'm wrong...
Right, I was pointing out that both are valid questions.
According to the Wikipedia definition at least, gear ratio is the ratio of the input speed to the output speed, so putting a larger sprocket on the wheel (or conversely, a smaller sprocket on the driving axle) would increase the gear ratio, creating a greater speed reduction. This reduces the theoretical unloaded freespeed, but, as I believe you're saying, can increase the top speed in torque-starved conditions.
Some other questions:
- Why is it important to keep electrical wires as short as possible? (Signal wiring and power wiring can have different answers, though there is overlap)
- What would be some advantages/disadvantages of using a smaller amount of a stronger but heavier material vs a larger amount of a weaker but lighter material (e.g. steel vs aluminum)
Unread 18-10-2012, 02:33
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Incorrect. A much smarter man taught me that the second most important part of the robot is... the drivetrain.
Do you want to know the third?
Unread 18-10-2012, 04:54
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Question Re: Robotics Question of the Day!
Drivetrain. Mr. Beast.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 18-10-2012, 09:09
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
For rookies our first question of the day is
What does FIRST stand for?
If you can't get that down no point in asking them mechanical questions because they aren't getting FIRST
Some team specific questions are also always good:
What year did we start?
What was our first game?
etc.
I always also enjoyed this question:
How do Mecanum wheels work?
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 18-10-2012, 09:11
A.The drivetrain
No, the second most important part of the robot is also the drivetrain.
So is the third.
Game piece manipulation is no higher than fourth on the list of robot priorities.
