Go to Post Didn't you know, I can be in two places at once? - Andy Baker [more]
Unread 09-01-2003, 02:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
RoboEmu 1.09 (supports PBASIC 2.5)
Well, I'm only 6 hours (or 30, depending on which promise) late, but here it is: RoboEmu 1.09. It includes support for everything in the spiffy new default code, as well as a number of bug fixes and new features.
Notably, it now supports PBASIC 2.5, has a user_mode display, supports autonomous mode. There's also some experimental support for user-changeable run speeds, but that may go away in the next version depending on how it works
As always, it's available at http://www.robbayer.com/software.html or in the white papers.
I know I ask this every time, but it's especially necesary this time: let me know how it works! I've checked everything I could think of, but with a whole new language, I'm sure I missed something. Likewise, I would like to know if anybody finds any other PBASIC 2.5 commands aside from SELECT, DO, LOOP, and the new forms of IF.
--Rob
Unread 09-01-2003, 06:45
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
I'd just like to thank you for your continuing service to the FIRST community, Rob!!!!
Unread 09-01-2003, 12:13
cybermind cybermind is offline
#1046 (PRISM Robotics)
cybermind is an unknown quantity at this point
Send a message via AIM to cybermind
Thanks. Your programs are REALLY helpful!
Unread 09-01-2003, 13:27
You're all very welcome. As long as people keep using them, I'll keep maintaining them.
I do have one question for some PBASIC gurus out there: What makes a line a complete command? I realized that I forgot to add the ability for commands to span multiple line to version 1.09, mainly because I spent a lot of time trying to figure out how to determine whether a line was "complete" or whether it spilled over into the next one. Here's what I've got so far:
Equal number of "(" and ")". Same with [ and ]. Even number of quote marks. No commas hanging off the end.
Anything else that defines a complete statement?
Unread 09-01-2003, 16:29
AKA: aXvXiA
I *think* a backslash at the end of a line will contain the next line in the command..
like
Serin COMA\COMB, INBAUD, [oi_swA,oi_swB,rc_swA,rc_swB, \
p2_x,p1_x,p4_x,p3_x,PB_mode, \
packet_num,p2_y,p1_y,p4_y,p3_y, \
p2_wheel,p1_wheel,p4_wheel,p3_wheel]
Unread 09-01-2003, 16:52
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
The trailing backslash will continue the line in this preprocessor, but it is not a standard language feature. It would be nice to have support for it in RoboEmu though... I would also like to give Rob my sincere thanks for creating and maintaining such a valuable aid!
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 09-01-2003, 19:27
If only life were so simple...
If you look at the new default code, you will see:
Serout USERCPU, OUTBAUD, [255,255,p1_y,relayA,p2_y,relayB,p3_y,p4_y,p1_x,p2_x,p3_x,p4_x,
p1_wheel,p2_wheel,p3_wheel,p4_wheel]
I think I've gotten it straightened out now, but I want to test it a little more before I release 1.09b. The change just isn't significant enough to merit a whole new version number...
Unread 09-01-2003, 19:28
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
Once I get some free time (haha, right) I'm planning on doing major testing. I do QA testing at a small software company, so I think I make a pretty qualified tester. Of course, my reasons are selfish, I just want the best tool possible to use when it actually matters. Just waiting for the free time to smack me in the face.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 12-01-2003, 01:35
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
could you add the OUTH variable. It's just a the Output pins 8-15. It'll make it easier to program the output byte for usermode
Unread 12-01-2003, 01:39
No problem. It's on the list of things to do for 1.10.
Unread 14-01-2003, 19:30
Adam Collet Adam Collet is offline
#0159 (Alpine Robotics)
Adam Collet is an unknown quantity at this point
Select issues
OK, I'm having issues with the new RoboEmu 2.5 Select support - I know you said its beta, but maybe some specific feedback will help.
I get the error "variable >132 does not exist"
I am doing a select command similar to what follow:
Select (arm_joint1) [hint hint about 159]
Case >ajoint1+slack
'some code
Case....
Case Else
EndSelect
Assumably, ajoint+slack is evaluated to be 132; and your program expects a variable there.
According to the examples that Parallax gave us for 2.5, an operator should be able to come directly after the "Case" statement. I'll send you the code.
"Without the wind, the grass does not move. Without software, hardware is useless.''
Thus spake the Master Programmer
The Tao of Programming
Translated by: Geoffrey James
Unread 14-01-2003, 19:52
Hmmm... I definately never saw any documentation from Parallax, so I didn't even know you could put an operator in there like that.
You're getting the current error because it only expects expressions, meaning it evaluates them recursively. Thus it added ajoint1 and slack and then replaced the appropriate part of the expression with the value it got back. It then tried to re-evaluate the new expression, thought it was a variable because it is only one word, and tried to lookup ">132."
Thanks for the heads up and I'll try to incorporate that into the next version as it should be VERY easy to fix. I also kinda forgot about the OUTH variable, so I'll do that too.
--Rob
Unread 14-01-2003, 23:16
select statement
Do you mean your program would expect something more like:
Select arm_joint1
CASE arm_joint1>ajoin+slack
etc.
etc.
EndSelect
Or that it only supports:
Select arm_joint1
CASE 0 to ajoin+slack
etc.
etc.
EndSelect
It would be much appreciated to have that update...when can we expect it?
Unread 14-01-2003, 23:20
No, I mean that my program doesn't expect any operator there and tries to evaluate the expression "couter=CASE", which in this instance turned into "arm_joint1=>132". Not pretty. I'm actually kinda surprised it didn't blow up. Oh well.
I'm REALLY busy until 9:00pm Thursday night (my Eagle Scoutmaster Conference), but I'll try to work on it after that. It shouldn't take more than an hour to add the support. As soon as I finish it, I'll let you know.
Unread 15-01-2003, 18:02
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Randomly playing around with RoboEmu and the default code. Clicked Switch 5, and up popped "Error: Variable P3_YMAX127 does not exist. Can't get value."
Looks like single line IF...THEN doesn't handle MIN and MAX operators.
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
PBASIC 2.5 Questions Noah Programming 6 10-01-2003 19:26
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
