Go to Post Maybe next season I want to develop and test a new metric for FRC scouting: Bumper Quality Rating (BQR). BQR-5: The platonic ideal of FRC bumpers. ... BQR-0: Moderate to heavy use of duct tape. I believe BQR would outperform OPR as a predictor of on-field robot performance. - Nate Laverdure [more]
Unread 23-10-2012, 17:07
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Bench top setup for demonstrating PID
We're building a bench top demo setup for experimenting with PID control. We'd use the Smart Dashboard to show internal state like the gain values, setpoint, and the PWM input value to the motor controller.
I'm looking for mechanical ideas on how to load a small motor with different levels of resistance in a safe way.
Does anyone have an example that they're willing to share?
Unread 23-10-2012, 20:12
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Bench top setup for demonstrating PID
what is the output you will be measuring? and how will you measure it? speed or position?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 23-10-2012, 21:50
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Inverted pendulums are pretty cool.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 23-10-2012, 22:17
If you are trying to control position, you could drive a speed-reduction gearbox connected to an arm with weights on the end. Physically limit the arm travel so no-one gets hurt.
If you are trying to control speed, you could:
a) drive a speed-increasing gearbox connected to a fan (make sure the fan has a shield to protect errant fingers and contain blade failures)
or
b) drive a speed-reduction gearbox connected to the shaft of a second motor, and short the second motor's leads.
Wear safety glasses.
Unread 23-10-2012, 23:10
AKA: Steve Peterson
Speed control is the goal. The fan idea is a good one. Right now we're using a CIM motor with a gear reduction and wheel attached, but I'm looking to go to a smaller BaneBots motor once I work out how to connect the US Digital encoder up to it.
I'm outputting the encoder values and current Jaguar value to the Smart Dashboard to monitor things.
Unread 24-10-2012, 09:30
AKA: Steve Peterson
We're starting with velocity control, using the Robodox guide as the template: http://www.chiefdelphi.com/forums/sh...d.php?t=106082
Our current setup is a CIM motor / CIMPle Box combo with the US Digital E4P encoder that came in the 2011 KOP. I'd like to replace the motor with something lower in power to make it a bit safer. Thoughts?
Unread 24-10-2012, 11:03
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
You might try having one DC motor drive another one. Permanent magnet DC motors act as generators when driven like this, though you may need to add some gearing depending on what target RPM you want to control. If you vary the electrical load on the generator it will translate into a varying mechanical load on the motor. Add a few switches and some lamps and you should have a simple variable load simulator. Depending on your application you may want to add some type of flywheel to add rotational inertia as well.
This is the zeroth day of the rest of your life.
Unread 24-10-2012, 11:08
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
I would love to see a picture when you get it all done
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 24-10-2012, 11:45
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
A 'pure' PID controller can act as a velocity controller if both of the inputs (setpoint and process variable) are velocity. In this case, D will be unused, I will act as P, and P will act as D. The issues come when the PID class has additional logic to handle the I term, such as resetting the integral when the error zero-crosses, capping the integral, etc. - I've heard the Jaguars reset I under some conditions, although I've never verified this.
Every time I have worked with a speed controller, attempting to adapt a position controller has always failed to meet the design requirements, and I design a better controller to handle it (usually incorporating some application-specific limiting of the integral term). Adding a Feed Forward term also helped with response time and oscillation.
Basically, what I'm saying is, don't be afraid to write your own PID math and not use the per-existing class.
Kettering Motorsports
Unread 24-10-2012, 12:09
Here are some other options:
http://www.chiefdelphi.com/forums/sh...90&postcount=5
Unread 24-10-2012, 12:12
AKA: Steve Peterson
The Robodox paper proposes implementing a PIDSource subclass (RPMSource) that wraps an RPM value, which is the wired to the WPILib PIDController. On each turn of the Execute() crank in our command, we take the elapsed time and change in encoder count to calculate an RPM value, which is fed into the RPMSource instance.
apalard -- it does look like we're not too far from doing all of the calculations ourselves, so we will probably give that a try if the build-in controller fails us. One item that hasn't been obvious is how far back in time to accumulate errors.
Unread 24-10-2012, 14:51
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
We're just finished building ours. We used a Victor + Globe motor with a VEX encoder (http://www.vexrobotics.com/276-2156.html) as feedback.
Still haven't figured out a great way to provide consistent, measurable resistance yet. But the globe is so slow we can at least test the PID loop by using our fingers to resist the position.
