Go to Post You all have made me think about this in a new way - which I appreciate. - aaeamdar [more]
Unread 16-10-2012, 16:45
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
URGENT Windriver not outputting code
We have been having problems with a no robot code light on the driver station and have tracked it down to Windriver not downloading the correct file in FRC Downlaoder Settings. However, when we try to navigate to the directory where the code is, there is no .out file. We try building the program, but we cannot find the file.
Unread 16-10-2012, 17:01
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: URGENT Windriver not outputting code
Can you post what WRWB outputs when you build?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 16-10-2012, 17:45
Registered ConfUser
AKA: Mark McGivern
I'll respond Wed. afternoon when we have access again.
Unread 17-10-2012, 16:15
Registered ConfUser
AKA: Mark McGivern
The sidebar is not telling us where the file is being built. Whenever we build anything, no .out files are created in any folders on the computer. We need serious help for an offseason in a few weeks and if we do not recieve help we will switch to Labview.
Unread 17-10-2012, 16:24
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
I have not used Windriver in a few years, but I think Connor wanted to inspect a dump of all the stuff it prints into the console/output area. It would probably give clues as to better understand what is happening during/at the end of the build process.
Unread 17-10-2012, 17:32
Seeing the build output will be helpful to see whether the build is failing or not.
Team 973 (2016-???)
日本語でOK
Unread 17-10-2012, 18:31
Registered ConfUser
AKA: Mark McGivern
I can't respond until Monday, but on the sidebar panel there was nothing that jumped out at me. I will have the full text copy-pasted for you then. Is there any other output you will require?
Unread 17-10-2012, 23:18
If you zip up the project and post it I could look at that as well.
Team 973 (2016-???)
日本語でOK
Unread 18-10-2012, 00:52
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Please see http://www.chiefdelphi.com/forums/sh...p;postcount=33. You may also have to turn on the display of file extensions. In the folder display in which you are looking for the .out file, Tools => Folder Options => View, uncheck "Hide extensions for known file types, OK.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 23-10-2012, 16:46
Registered ConfUser
AKA: Mark McGivern
Garyk, I did every step in your list. The driver station LED panel connected, downloaded, and showed the robot code light, but my existing code project did not show a robot code green light. I uplaoded it http://www.ge.tt/7uIL06Q/v/0?c so someone can attempt to find a problem, but we may have to recode everything.
Unread 24-10-2012, 09:39
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
So you're seeing nothing in the directory where you expect output?
When you build, the last few lines in the Build console will be:
building CommandBasedRobotTemplate/Debug/CommandBasedRobotTemplate.out
make: built targets of C:/WindRiver/workspace/PIDPrototype/PPC603gnu
If you combine those two strings together, it identifies the full path to the file the linker is creating:
C:\WindRiver\workspace\PIDPrototype\PPC603gnu\CommandBasedRobotTemplate\Debug\CommandBasedRobotTemplate.out
This is the path that should be set in the FIRST Downloader Preferences -> The file to download to the Robot field.
Do you have some NetConsole output that you could share? In particular, do you see this line:
* Loading FRC_UserProgram.out: FRC_UserProgram
Unread 01-11-2012, 21:34
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
At this point some well taken screenshots or copy and pasting of errors may be helpful
another thing you might want to do is create a mew project and copy your code into it then use it instead
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
