Go to Post "Splet" is the sound a frog makes when it hits pavement at 187 feet per second. Don't ask me how I know. - dlavery [more]
Unread 24-10-2012, 19:07
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Open vs Closed Gearboxes
A few of us were sitting around a table in the shop the other night discussing the pros and cons of open and closed gearboxes.
This was brought up during a challenge for a small group of students to redesign a transmission for the 2012 robot. We have done both in the past, but what are the experiences of other teams?
We have run custom (not as aesthetically appealing as other teams have) open transmissions; and have used more than our fair share of COTS transmissions, which are typically enclosed. We have always had success with both. What are your experiences?
What lessons have you learned that can be shared with others?
*Note: This is not meant to be a standard vs custom thread, but focused on open vs closed designs*
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 24-10-2012, 19:20
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Re: Open vs Closed Gearboxes
"Junk" gets all up in them too easy. There really isn't much of a gain by having them open. If your worried about the weight, just put something thin around them.
We make easy things look difficult, everyday!
Unread 24-10-2012, 19:43
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Haven't had much "junk" get in our gearboxes and we leave them open. But I do agree, you can wrap some thin polycarbonate around them.
Most teams have issues with grease getting everywhere. The last two years we switched to a DuPont Dry Grease which has fixed that issue. For a direct drive WCD setup, its a whole lot easier to run open gearboxes too.
Why we do it:
-Lighter
-Less parts
-Internals are Visible
-Easy maintenance (Dog shifters, Chain etc..)
-Easier to teach new kids (not really a design decision just a benefit)
-RC
R.C.
MadTown Robotics Team 1323
Unread 24-10-2012, 20:33
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by R.C. View Post
Why we do it:
-Lighter
-Less parts
-RC
This. In my experience, unless grease splatter is a major concern, open is almost always better, mostly because of weight. For example, running a Toughbox with delrin spacers instead of the usual aluminium enclosure saves over half a pound per robot. We ran them that way, and aside from a little grease getting thrown around, they ran like champs.
You may be a little too worried about stuff getting in the gearbox, and not considering the maintenance and weight benefits. I personally have never seen a gearbox fail from foreign material inside. Usually, binding that you might think was caused by stuff getting caught in the gears is caused by improper grease use.
-Plutarch
Unread 24-10-2012, 20:57
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
dust covers are always a good idea. nothing sucks more than losing because of something stupid like your robot sucking up some kind of debris (carpet fuzz, screw, other stuff) and jamming the gearbox which takes out 1/2 your drive
My Instructables
Unread 24-10-2012, 21:09
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Also keep in mind safety issues... An open gear box makes it a lot easier for someone to lose a finger! This can often be taken care of with appropriate warning tape and proper safety procedures, but you want to make sure your safe with an open gear box design.
2016: Lake Superior WFFA
Unread 24-10-2012, 21:14
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
Maybe use packaging tape to cover open areas to prevent dust/debris and hands from getting into the gears.
Unread 24-10-2012, 21:23
1502's Avatar
AKA: Ryan G
Packaging tape is a perfect idea. It weights little to nothing, is easy to take off, easy to replace, and pretty cheap!
Unread 24-10-2012, 21:24
and cause it's sticky it will collect gunk better...
My Instructables
Unread 24-10-2012, 21:56
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Hope it never gets sucked in to the transmission though!
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 24-10-2012, 22:07
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We covered our supershifters with metal flashing this season. Weighs next to nothing but next year we'd probably use thin lexan so we can see into the gearbox.
1058 PVC Pirates 2016 - xxxx
Unread 24-10-2012, 22:15
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
We had Gearbox shields on the bottom of our gearbox for the first time last year. We did this because we were running worm gears and had to keep them free of debris, else lose more efficiency. The shield was made out of 1/32 aluminum and was very light.
We're doing so again on a new gearbox, this time it's less of an afterthought.
Unread 24-10-2012, 23:09
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Historically we have machined new sideplates for the AM supershifter or Gen 1 although we have also added provisions for a third motor in some seasons. Per my understanding Andymark's fully covered gearboxes are more for legality and increased functionality in a greater number situations. (they can't get fingers sucked into them, they can be safely run on a table, and more easily interfaced to a great number of designs, etc.) Custom sideplates eliminate alot of functionality that while important for mass production/consumption may not be important in your design. This is traded off in favor of things like reduced weight, better packaging, more favorable gear ratios, etc which most teams find desirable.
In any case, we cover our otherwise open gearboxes with thin polycarb which seems to work well.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 25-10-2012, 09:00
Gears produce metal dust and that dust can find it's way into speed controllers and other electronics. If you don't place covers then insure that there is some distance between the transmissions and electricals.
Unread 25-10-2012, 12:20
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
We used some aluminum tape last year on our open frame gearbox to seal it. http://www.mcmaster.com/#aluminum-tape/=jvj3k9
Not the cheapest, but it sealed well, lite weight, conformed to the surface, looks shiny, trims to edge very well, and very durable. One roll will last you for a long time.
-T
