Go to Post "Needless to say, my Roomba will be making my toast from now on" -Colbert - artK [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 25-10-2012, 13:39
Dragonslayerend Dragonslayerend is offline
DuncanDynamics lead programmer
AKA: Tom Xiong
FRC #3970 (DuncanDynamics)
Dragonslayerend will become famous soon enoughDragonslayerend will become famous soon enough
BDC-COM reports "Unable to contact boot loader" when trying to update firmware
I get a report of this:
How do I fix this? I have all correct cables 6p6c and correctly assembled DB9 connector. I found someone with a problem like this but it was from 2010, was there a patch for this if so please help me I'm stuck.
Unread 26-10-2012, 01:35
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: BDC-COM reports "Unable to contact boot loader" when trying to update firmware
It has been a while since I've seen that error, just to note, it looks like you posted just a thumb and not the full image. If memory serves, try flashing the firmware in recovery mode (WARNING, HERE BE DRAGONS), which will contact it at some lower level I think, and upload the firmware that way. Recovery is in one of the menus. Normally it is used for an otherwise nonfunctional jag, if something goes wrong in this process, you can brick the jag, so make sure not to unplug it, and I'm not responsible if anything bad happens.
Good luck,
Oliver
Unread 26-10-2012, 03:56
AKA: Tom Xiong
Haha okay I'll see what happens thanks, all 4 jags are doing this though could all of them have this problem?
Unread 27-10-2012, 00:48
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Also, make sure you have given the Jaguars unique ID numbers before flashing their firmware. If more than one Jaguar has the same ID, it will give the same error, if I remember correctly.
I'm right 90% of the time, so why worry about the other 3%?
Unread 29-10-2012, 12:05
AKA: Tom Xiong
I can't even set ID
Unread 02-02-2013, 16:48
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
We're having the same problem.
Was there a resolution to this issue?
Unread 02-02-2013, 19:54
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
I've run across this a few times. What has always worked for me, (if it wasn't truly bricked) was to use a USB to Serial on my laptop, with the DB9 connector built as documented, a 6 wire can cable, and ONE and ONLY one Jaguar attached and terminated.
I was then able to perform a recover device. But you can only have one JAGUAR on the bus for it to work.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 04-02-2013, 21:10
graham.robots graham.robots is offline
FRC #4024
graham.robots is an unknown quantity at this point
We are having the same problem, but we have been only using one jaguar at a time in the first place... any other solutions?
Thanks in advance,
Team 4024
Unread 04-04-2013, 03:09
AKA: Tom Xiong
What happened was for some weird reason it was the DB-9 connector. I fixed the problem after making another one and using the new one instead. Though I still don't understand how it happened. It got even more confusing after I tried the old DB-9 connector that gave me problems again and then it miraculously worked! Physiscs is confusing but you should try out with a new DB-9 connector, or might as well just make a custom cable that plugs straight into a serial port.
Unread 16-04-2013, 02:41
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Two of our new Jaguars have this problem. Never got the LED to light on either one. Students labeled them, and put them in an anti-static bag to deal with them later.
Now is later. We thought it may be excess conformal coating, which was a visible translucent film on the power terminals, but scraping them had no effect. The power pins for the encoder give 5V, but still no LED, or boot loader. Time to get RMA's.
These were in the last batch of Jaguars we bought this year, after our robot was outfit. The initial discovery was made when we tried to flash with the 107 firmware, to prepare for competition. Luckily, we had no failures of any Jaguars, and had a few spares that were working.
-- Len
Unread 27-08-2013, 17:52
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
We were updating a VEX Black Jag firmware with bdc-com and PC crashed. The Jag LED was dead. We researched this a tried all suggestions to restore communication. Contacted VEX and determined we needed to send back to VEX to fix. We sent the "bricked" unit back w/ RMA and the repaired unit was quickly returned. The only cost was shipping to VEX.
Two thumbs up for their customer support.
