Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 27-10-2012, 13:40
Re: Robot "kicks out" when it goes right
From the video, this looks like a code issue.
Have you done anything at all to the code in the robot -- including re-loading it -- since the last time the robot worked properly?
Unread 27-10-2012, 13:51
While someone looks at the code for problems, have someone else double-check the wiring from your speed controllers to your motors. If something is cross-wired, you can get really weird results that only show up under specific conditions.
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
We lost our old code from last year and are trying to reprogram it for an unofficial competition coming up soon. We are using the new compact cRIO - last year we had used the cRIO I. The robot hasn't worked well since we changed cRIOs and lost the code.
Our programmer was thinking that it had to do with pointers in C++; he had been getting the "MotorSafetyController.cpp at line 123" error, but he fixed that and the problem is still present.
We'll check on that too, thanks. We are pretty certain nothing has changed since last seasons competition - where the bot worked fine - but there have been a lot of people around the robot so anything is possible.
Unread 27-10-2012, 13:59
Are you using one or two Joysticks? Arcade or tank style?
Are you using the WPI library functions for this, or home brew?
Unread 27-10-2012, 14:09
Registered ConfUser
AKA: Mark McGivern
We attached our code in our OP and we are using WPILib. Two joysticks, one is arcade style.
@Alan: The wiring is solid.
@akoscielski: We reset the jaguars but it is still having the problems. Whenever we move the drive joystick the SLIGHTEST bit towards the right, even a tiny, indistinguishable bit, the robot kicks out.
Unread 27-10-2012, 14:28
Registered ConfUser
AKA: Mark McGivern
Oh.
My.
GOD.
The problem was that I forgot to put the sidecar power cable in.
[sarcasm]I want to slit my wrists now.[/sarcasm]
Sorry for wasting your guys' time.
Unread 27-10-2012, 14:36
I'd like to learn something here.
Could someone explain why this would cause the drivetrain would work fine in the forward, and reverse, and rotate left directions, but not in the rotate right direction?
Unread 28-10-2012, 01:56
Assume four motors, two on each side. Further assume that the wiring is such that one side's motors run "forward" and the other side's motors run "reverse" for forward travel of the robot.
The DS can "sneak" some power from the PWM signals coming from the cRIO. When the robot is being commanded neutral, it's getting four 1.5ms pulses every so often, and that's enough to make it work. When it's being commanded either forward or reverse, two of the signals get shorter, but two get longer, and it balances out. When it's being commanded to turn left, all four signals get longer. But when it's being commanded to turn right, all four signals get shorter, the DS gets starved for power, and things stop working.
Unread 28-10-2012, 15:57
Thank you. The DS "sneaking power" from the cRIO's PWM signals was the puzzle piece I was missing.
