Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 27-10-2012, 16:39
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
#25 Chain Drive Experience ???
Just wondering what everyones experience has been with the use of #25 chain between the middle and outer wheels of a 6 wheel robot (ie 2 loops of #25 chain on each side of the robot). I'm hearing different stories and have seen broken robot #25 chains being changed on the field right in the intermission between finals rounds. I also hear it will stretch substantially more than #35 chain. I know 1310 has used it in past but was using #35 last year.
Also, anyone confirm that #35 chain in the above configuration doesn't stretch much at all, any slack accumulated appeared to us to be caused by wear on the aluminum sprockets (ie the slack remained even after replacing the chain with brand new chain).
Unread 27-10-2012, 16:52
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: #25 Chain Drive Experience ???
We did this for the first time last year. Chain stretch was pretty dramatic, more than our tensioner designs could handle, though this was just as much a function of bad tensioner design, as it was increased stretch from the #25. I think we ended up having to pull a link about 2 or 3 times per chain over the course of the season.
Additionally, we made the mistake of using #25 chain without precision turned spacers. We used spacers cut from sheet stock which got the dimensions "about right," to a degree which would have been acceptable for #35. "About right" wasn't enough, and we threw a lot of chain due to sprockets not quite mounted in the same plane. Finally, we used smaller sprockets than we needed to, which increased load felt by the chain, and reduced the slack needed to throw it. We never had a break or throw which looked consistent with overloading the chain, and it should theoretically never happen with the loads experienced in a typical FRC drivetrain, but I'm sure this intensified the other two problems.
I know of many success stories as well, and I'm pretty confident that we could have made it work with better tensioners, bigger sprockets, and more precise spacers. But the experience left a pretty bad taste in my team's mouth about the whole thing, and we're likely going to be using belts instead next season. More upfront design work required, but much lower maintenance. There are advantages to #25 chain; that's why a lot of very good teams use it. But proceed with caution.
Unread 27-10-2012, 17:07
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Jibsy will become famous soon enoughJibsy will become famous soon enough
3756 used #25 chain last year without issue. It does stretch quite a bit, meaning you have to either remove links or have some sort of other tensioning system to adjust every once in a while.
I personally love working with #25 chain... it feels almost like working with jewelry compared to #35. As mentioned by Joe though, it's quite a bit more picky in the way of sprocket alignment. We used 1/6" plastic spacers (from McMaster IIRC) to line them up, and they never popped except for when one of our sprockets came lose.
We use the #35 chain and sprockets that we have sitting around from the KoP for prototyping and practice bots, but I don't see us ever leaving #25 and 1/16" spacers for competition. (Edit: We had undersized aluminum spacers, leaving space for adjustments with the small plastic ones).
Here's a picture of our 2012 drive train. We had slots in the wheel brackets for tensioning. Worked well, but a pain in the rear to adjust in a 10 wheel drive -.-
Unread 27-10-2012, 19:48
de_ de_ is offline
AKA: Dave Edwards
Thanks for the feedback. Lots of (critical) gotcha's to watch out for.
Just in case I am missing something, what is the offsetting benefit of using #25 if there was so much stretching and retensioning required etc. Is it primarily weight savings (with sprocket weight savings) ?
Unread 27-10-2012, 22:25
Jibsy's Avatar
Mentor - 3756, 4525
AKA: Jared Baribeau
While I can't recall exactly where I read it, I remember seeing somewhere that #35 chain is about 2.5 times the weight of #25, so the weight difference is significant. For the small amount of time it takes up front to line up the chains properly, and re-tension them a couple times throughout the season, the weight you save is definitely worth it. It also looks fantastic and is much nicer to work with, but those aren't exactly competitive advantages.
I highly recommend using multiple small plastic spacers if you join the #25 side. Makes lining up the sprockets a breeze.
Unread 27-10-2012, 22:47
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Team 33 uses #25 chain almost exclusively on our robots. It is strong enough for pretty much any FRC application. Like many have said sprocket alignment is very important. Also, in our experience the chain doesn't actually stretch - the slackening is from the sprockets wearing in. Generally if you have a way to tention the chain about a half inch (such as a sliding bearing block) that is enough to take care of any chain stretching. Alternatively, we actually ran with loose chain in 2012 (chain was not pulled tight by a tentioner) and never threw a chain. I think a lot of the problems people have is because of misalignment: if you have confidence that you can align the sprockets well then I would give it a try.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 27-10-2012, 22:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
25 Chain is more than enough for drivetrain applications, assuming you have it aligned correctly.
To align sprockets, get a nice flat edge and span the distance between the sprockets. You should quickly see if they are aligned.
If you're direct driving the center wheel, use 25 chain for the front and back. Even a break won't put you out of business. If you are are not direct driving, use a double sprocket. Run one chain to the wheel in front of the transmission, and one behind.
The key to a successful drivetrain is NEVER reling on a single component, because it will break. From experience. (See Michigan State Champs 2011 where we sat motionless for 2 matches).
Unread 28-10-2012, 10:29
philso philso is offline
FRC #2587
This past year, we used #25 chain to link the motors to the ball shooter wheel. We found that some of the sprockets that appeared to have irregular/non-standard tooth pitch. The large (28-32 tooth range) and small (10-16 tooth) sprockets were aligned so that they were co-planar. When rotated slowly, by hand, the chain can be seen to "climb" on top of one of the teeth of the large sprocket. This would always occur at the same spot on the sprocket regardless of which part of the chain was wrapped around it. We did not get significant wear on the sprockets or chain stretch. All the sprockets we had trouble with were stamped from sheet aluminum. On some of them, we noticed teeth that had "notches" in them, when new. It looked like the tooth pattern was "wrapped" around a circle that was slightly too large. We had to file the notch away to make the chain seat properly around that tooth.
I posted about this problem on a thread about #25 chain earlier this year. I seem to recall that some other teams ha no problems and some had similar problems and that it may be dependent on the supplier or even the batch of the sprockets.
Phil
Unread 28-10-2012, 15:19
Tom Line's Avatar
Phil, we've seen the same thing. We generally just throw the ones like that away. They're so cheap it's not worth sending them back. On high torque low speed applications you can sometimes wait for them to break in, but on our shooter it was scary when they started jumping at 5k rpm.
Unread 29-10-2012, 07:16
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
There are several other threads where this has been discussed which you can read if you do a search but it basically boils down to several items already mentioned:
#25:
is strong enough for the drive train
is lighter
is more fickle about alignment
#35:
is heavier
more tolerant of misalignment
easier to work with.
My preference for drive is to use #35 and for mechanisms to use #25 in most cases. I don't like to have to worry about throwing a chain or even having to do real maintainance on the drivetrain which is what pushes me in this direction. Also I'm more comfortable with Al sprockets under that kind of wear at the #35 size. I know both work, but to me the trade-offs lean towards #35.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 30-10-2012, 09:04
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
In the past 4 years I have been involved with the team, 610 has used 25 chain on our drivetrain 3 times. We only popped a chain off once. Alignment of the sprockets is crucial, but not really that hard if you design it in. Strength does not seem to be an issue, but larger sprockets lead to lower tension in the chain if you are concerned. It's hard to say, but the "stretching" one sees with 25 chain may actually be wear in the aluminum sprockets. In recent years, I have noticed the sprockets from AndyMark are made out of thinner sheet metal without any chamfer on the teeth. It looks like they are just cut on a waterjet. I'm sure this reduces their cost of manufacturing, but I liked the thicker ones with chamfers to guide the chain, and I suspect they would not wear as quickly since the base of the teeth was wider.
The real benefits to 25 chain are lighter weight and smaller size. Also, if you get the "dark soul" chain tool, making chains is really easy, with no more master links! It's actually much easier to work with than 35 chain.
Depending on the application, I would be hesitant to use 25 chain on arm joints and other heavily loaded mechanisms. Our flipper arms this year were powered by two 25 chains, and they broke a couple times. I think the shock of driving over the barrier or pulling the bridge down was more than it could handle over time.
Unread 30-10-2012, 11:21
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
With everyone saying its not the stretching but its the sprockets. Is there anyway to stop that? Would making steel sprickets be beneficial and still save weight?
We are thinking of switching but I gotta make sure before I use them. We will most likely use them on our prototype drive train this year.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 30-10-2012, 11:38
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
During my time on 1503, we ran #35 chain in the drivetrain. While #25 is plenty strong enough, the biggest concern was sprocket allignment. Rather than spend hours machining spacers to 0.0005" tolerances, we felt our "quality" maching time could be better used for the parts that really needed it.
Personally, I'd rather spend the extra time and run #25 chain all around. The weight savings is huge.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 31-10-2012, 22:30
de_ de_ is offline
AKA: Dave Edwards
Originally Posted by Rob Stehlik View Post
.....but I liked the thicker ones with chamfers to guide the chain, and I suspect they would not wear as quickly since the base of the teeth was wider....
....the "dark soul" chain tool, making chains is really easy, with no more master links! ....
Hi Rob
Where do you buy the thicker AL #25 sprockets ?
Re the Dark soul tool ( http://www.team221.com/viewproduct.php?id=70 ) I had no idea that it got rid of the masterlink. Thanks
Dave
Unread 31-10-2012, 22:53
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Hi Rob
Dave
AM used to sell thicker sprockets with a chamfer. Now they are thinner with no chamfer.
-RC
R.C.
MadTown Robotics Team 1323
