| Thread Tools |
Rating:
Display Modes |
Source of 1/2 wide 20 DP, 14.5 PA gears
Looking for a source of gears that are
- 1/2 wide (so far only found 3/8") - 20 diametral pitch - 14.5 deg pressure angle as per gears used in AM Super Shifter transmissions |
Re: Source of 1/2 wide 20 DP, 14.5 PA gears
http://wcproducts.net/gears-20-dp/
Should be what you are looking for but, they are .400 and .600 in with. Last edited by MattC9 : 27-10-2012 at 16:51. Reason: Grammar |
Wasn't aware of that source. Thanks. I better go measure my gear
SDP/SI (Stock Drive Products/Sterling Instrument) has gear stock from which you could turn any custom face width. (Other diameters available too.) Of course, their online ordering system continues to be horribly broken (and irreconcilable with their phone/mail ordering system), and their shipping to Canada is typically UPS with all of the associated brokerage fee headaches.
Linn Gear also sells 20 pitch, 14.5° pressure angle gears, but they apparently don't have an online catalogue. |
Will definitely try Linn! |
Martin Gear and Sprocket
I believe Canadian Bearings (and probably BDI) can bring in Martin gears locally. |
