Go to Post You can sometimes step outside the box if you have properly thought through the question. - Jim Zondag [more]
Unread 14-01-2003, 23:20
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
Optical Sensing on the ramp
After looking at the field, I immediately had a question, would we be able to use the optical sensors on the ramp, or will it have to be a "dead-reckoner" as soon as the optical sensors hit the wire mesh? So I looked closer, and it seems that the aluminum supports are the continuation of the reflexite tape. My question would be, would the aluminum be enough for the optical sensors to recognize a lighter surface?
tenkai
Unread 14-01-2003, 23:24
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
yep, it is. it doesn't pick up the wire mesh ramp, thats probably because FIRST chose a coper plated wire mesh. and then the hdpe up top also reflects and the sensors detect it. so you can just set it to go forward when both sensors detect a reflection. and the aluminum going up the ramp, they are all painted black except for the ones in line with the tape, those are left shiney so you can follow them up
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Q&A Discuss: Does the line continue up the ramp? CD47-Bot Extra Discussion 5 18-01-2003 01:01
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
scoring ramp dimensions archiver 2000 3 24-06-2002 00:13
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
