Go to Post I got something totally different from my FIRST experience. to me the spirit of FIRST is all about sharing. during the 6 week build period, you share yourself with the other people on your team. at the competition, you share your creation with everyone who watches your 'bot play the game. - George1902 [more]
Unread 26-10-2012, 11:37
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Re: Castings in FRC
In 2011, we overmolded performance wheels with a urethane tread. Performed well, but we've also had good luck with the Hi-Grip wheel that came out in 2012. Here's some pics of our setup..
https://plus.google.com/photos/10248...CK2p1N3ssbWSRQ
FRC Team 3489 "Category 5"
Unread 26-10-2012, 11:48
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: Castings in FRC
Originally Posted by JamesBrown View Post
Interesting, there is a guy on there who has a furnace that burns waste oil, it appears to be made out of a keg (undoubtedly lined with some sort of ceramic) and an old vaccum cleaner. Pretty cool.
A friend of mine has built one of these waste oil furnaces. It gets hot enough to cast iron, (which he has done). There are only a few hobbyists who ever attempt casting iron. This is an order of magnitude more difficult and dangerous than casting aluminum. For aluminum casting a propane furnace is clean, convenient, and not overly expensive unless you plan to do a lot of casting. Some folks use a charcoal furnace, which is easier to build from scratch, but does have additional drawbacks. The waste oil furnace is relatively expensive to build, quite large to store, and requires a fairly large, open, and dry yet fire-safe area to operate. A location suitable for casting with a propane furnace is generally easier to locate. You might try checking the cost of just a used stainless steel keg sometime to see how quickly the parts start to add up.
This is the zeroth day of the rest of your life.
Unread 28-10-2012, 00:27
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Re: Castings in FRC
Our art department casts both aluminum and brass. Some of the other schools in our area have the same capabilities in their art departments. Artists are a good source of experienced people and equipment that can help with casting.
Unread 28-10-2012, 11:15
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Castings in FRC
Originally Posted by DampRobot View Post
I'm not sure if this was what you had in mind, but in 2006 one team cast (out of plastic) meccanum rollers. I forget what team it was, but they were featured in the 2006 "Behind the Design" book. With the rise of 3D printing, even printing metal through sintering, I doubt many teams will use casting in the future.
In 2005, Team 190 cast custom urethane rollers for their mecanum wheels. Team 357 did one better in 2006 by not only casting the urethane rollers, but casting the aluminum hub as well. Their hubs were cast using a 3D-printed mold, if I remember correctly.
Zan Hecht
Unread 30-10-2012, 10:56
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Re: Castings in FRC
Hi All
Last year we needed 2” x 7” dia. aluminum material for wheels
We had lots of scrap from robots over the years and I have an electric kiln,
I had not done any casting with aluminum for years, (like others I learned foundry at high school) with no green sand we used plaster for a mold (after it was baked to remove the moisture) it worked well enough to get us the billet material at a reasonable cost.
It was a great experience in Up-Cycling and I have hopes that we can explore more options this year,
To that goal I have invested in a set of foundry tools and built a molding bench.
I should say “made” a set of tools and a bench as most of the tooling was outrageously priced for as simple as it is.
I went with petro-bond sand instead of mixing my own “home brew” a little more expensive but better results too.
Altogether total cost was about $400.00 including the kiln + time and brain power
I have found many books on the subject on amazon
If there is an interest I will list materials resources and supplies as I did with 15c machine shop.
Have Fun
Geo.
watch the oz, the lbs take care of themselfs
Unread 31-10-2012, 03:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Castings in FRC
Originally Posted by George View Post
Hi All
Have Fun
Geo.
Did you need to adjust the alloy for better casting properties? (I assume you started with mostly wrought Al-Mg-Si alloys like 6061.)
Did you attempt any heat treatment afterward? (If so, what was the process, and how did it go?)
Unread 31-10-2012, 10:08
tsaksa's Avatar
Re: Castings in FRC
If you plan to do some casting, it is best to get your raw metal from scrap castings. That way you know the specific alloy was appropriate for casting in the first place, and not stamping, extruding, machining, etc. There is a lot of scrap metal out there, so if you hook up with the right source it is usually easy to get enough of the correct raw material at modest or even zero cost for casting projects. The real issue with casting is having a safe location and the right tools and experience to do the work in a safe manner.
Unread 31-10-2012, 10:28
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Castings in FRC
Ive seen teams use casting of metals - but have any of these teams tried using this process to create stronger metals.
For instance: say you were making a wheel shaft out of steel. You could add just a trace ammount of beryllium to the steel and close to double your strength. Without adding any weight.
It's sort of a bad example but I'm curious if any teams with a material sciences mentor has experimented with alloying their own metals.
Unread 02-11-2012, 15:04
#0060 (Bulldogs)
Re: Castings in FRC
As our final product was to be wheels other than flux and de-gassing we did not adjust the alloy, nor attempt artificial aging or annealing, this was a spur of the moment measure, the cast billet worked fine and machined well, with no flaws and no failures.
We did not send any of our cast samples out for analyses, so I can’t comment on the alloy content, other than you are correct as most of the material we used was 6061 with a good helping of 6063
If we decide to cast gears, high strength components or wear parts it would be a different story, in this case a bit of zinc would go well,
fyi Blast from the past; http://www.youtube.com/watch?v=fJyD8...eature=related
Have Fun
Geo.
